iamchris
Member since June 2023
Post by iamchris on Mar 27, 2024 8:57:10 GMT -5
More often than I'd like, I find myself reversing progress during dry polish. I have a super cerium wheel at home, but also have access to a 50k diamond polish wheel at my lapidary club. I used to find it handy to remove the cab from the dop to just heat it up on the wheel until the wax is a bit pliable, and then pop it off. However, I've had coprolite and some other quartz fracture on me from the higher heat so I no longer do that. However, I still have the problem of residue getting in small fractures or porosity. I'm struggling a bit with the benefit of doing a dry polish, rather than just getting some 8k, 14k, 50k wheels and using those to more easily and safely get a nice shine (both for the rocks and health-wise for me). I've heard that some material doesn't take a good polish unless you get it hot, but those seem to be less common. Why does everyone trend towards dry polishing rather than having some more resin wheels? I have some nice cabs that I've finished up to 3k, and while I know the obsidian will do fantastically, this guy will have a bunch of white spots if I dare to take it any further with my current equipment.
Post by hummingbirdstones on Mar 27, 2024 10:03:54 GMT -5
Chris, can you refresh my memory on what kind of machine you have?
iamchris
Post by iamchris on Mar 27, 2024 11:34:45 GMT -5
Highland Park CB8
I have threaded inserts at the end of the arbor shaft. Currently have a Kingsley North flat plastic mount, with an adhesive felt pad, charged with super cerium. Also makes a bit of a mess, whereas the resin wheels would be a bit cleaner.
goldfinder
Member since December 2020
Post by goldfinder on Mar 27, 2024 11:52:58 GMT -5
Sorry if I misread your post, but are you using cerium oxide dry? It's typically mixed with water and used as a wet slurry. I think even the precharged pads/wheels are supposed to be kept moist or on a slow water drip.
An ultrasonic cleaner works a treat to remove the cerium from the vugs and cracks. Although soft/fragile materials aren't recommended to go in an ultrasonic cleaner.
chris1956
Member since July 2022
Post by chris1956 on Mar 27, 2024 12:32:51 GMT -5
When I started, I was polishing a lot of Petoskey stones. Because they are porous, polish powder would collect in the pits and look terrible. I didn't know much about ultrasonic cleaners then, so my solution was to get 14k and 50k wheels. Not sure why I didn't get 8k wheel. It might have been because I took my 80 and 120 grit wheels and put them on a two wheel arbor. Couldn't fit another wheel? Anyway, the 14k and 50K wheels work great. On Petoskey stones I can see a lot of improvment in the 14k wheel. Not as much for the 50k but I can tell it is polished better because the stones are slick as %@$! after the 50k wheel. You might try the ultrasonic cleaner as it really does seem to clean up stones well (although I haven't tried it on Petoskey stones yet). Dang wheels are expensive these days.
I was also thinking that when I did use polishing compounds, I keep the wheel somewhat moist. I do remember it didn't take much buffing to really heat up a Petoskey stone.
iamchris
Post by iamchris on Mar 27, 2024 16:47:56 GMT -5
Thank you goldfinder and chris1956! That's interesting you say that, the buff at my rock club says explicitly to use it dry. I don't think I've ever seen them recharge it either. As a result I've also done it try. I personally mixed my super cerium with water to create my own paste, and then applied that to the wheel and waited for it to dry. Not long enough, because it proceeded to spray a dividing line through my workshop on the floor walls and ceiling. But that was the intention anyway. 😆🤦♂️🤷♂️
Post by rockjunquie on Mar 27, 2024 17:00:02 GMT -5
A buff is used dry. Do you mean wheel?
I used to use the 50k wheel. I didn't like it. I went back to paste on the 50k and 100k. Not messy. It doesn't clog porous stones are easily, IMHO.
I use 8k and like it.
Post by rmf on Mar 27, 2024 18:03:47 GMT -5
Diamond wheels are great until they are not. When I polish (Agates and Jaspers and obsidian) I take them down to 3000 grit via diamond Nova wheels. I have and 8000 and a 14000 diamond but Then it becomes about speed of finishing. So I go to conventional polish. I have used Tin Oxide(SnO) for 50 years and have not had good results with cerium. However, some on here use a much higher grade of cerium than I have tried. That said the SnO I add about 3oz of Linde A with the tin to speed my work. I use to polish on leather with a spray bottle. When the end plate leather failed they nolonger carried the good glue so I just used my muslin wheels. I polish almost everything on Muslin with SnO+ linde A and get a great polish. The key whether Leather or muslin is to start wet with the polish and work to dry. Especially quartz, glass, and opals are heat sensitive so I use a mister to keep the heat down as well and use the fine fibers on the edge to lightly polish the heat sensitive part after I have worked the wet on more of the center of the buffer.
Other rocks that are softer like travertine I go to 8000 Nova wheel. I discovered that Lapis polishes best on a diamond cloth belt, not a resin wheel.
Polishing happens in two steps wet does some cutting and dry finishes the polish but the work you do while it is wet is key.
gemfeller
Member since June 2011
Post by gemfeller on Mar 27, 2024 18:16:08 GMT -5
@iamcrhis Tell me if I'm misunderstanding your post. There's always something new under the sun but I've never heard of using cerium or any other oxide powder dry on a buff. I use them in a wet slurry on felt and leather polishing wheels. Polishing gets done when the wheel is almost dry but not quite. When you feel a tugging sensation you're polishing. But don't continue very long or the stone will heat up and crack. The key for me is to repeat the procedure several times, spritzing a bit of water on the wheel in-between, until I'm satisfied with the polish.
You need to build some sort of shield if possible to prevent redecorating your shop area and yourself. But I think most people use far too much slurry anyhow. Cutting down on the amount might help.
iamchris
Post by iamchris on Mar 27, 2024 18:47:31 GMT -5
rockjunquie perhaps I'm misusing the term. Sure looks like a [wagon] wheel, but I didn't want to confuse the terminology with a soft resin wheel. BTW this is one of the things that drives me bonkers about the HP CB8. Why it couldn't have been 1 inch longer to catch the spray is beyond me. My workshop would have a much smaller dividing line. And those red covers are a pain to put on. Wish I went with the KN8. rmf thanks for the info gemfeller I'm not pretending to know what I'm doing. There's a two wheel polish machine at the Rochester Lapidary Society that has 50k diamond on one side and cerium (presumably super cerium since it's white) on the other side. It has a paper sign saying to never spray water on it so I thought that's how it was supposed to be done. I'll inquire next time I go to see why they're of the opinion that it should be done dry. There's a good chance I used too much. And good call on taking breaks to avoid cracking. Confirmed, it's a con, not a pro if I can simply peel the stone off the dop or if it burns my hands like it has in the past, haha. Would it also be considered smarter to keep the stone closer to the center of the wheel to keep the wheel speed (i.e. heat) lower?
gemfeller
Post by gemfeller on Mar 27, 2024 19:48:29 GMT -5
iamchris I never claimed to know what I'm doing either. There's a new cerium technology I'm becoming vaguely aware of that calls for dry polishing on special disks. Maybe that's what your club is using. Somehow I got it into my head you were using cerium on a muslin buff, the stitched kind used for metal polishing. What material is the buff on your personal machine made of? I bought a super cerium resin wheel for my Genie. I've used it both wet and dry and so far all it does is ruin the polish I already have from previous steps. I know I'm probably using it wrong but as a friend says, everything's easy once you know how. I'm not there yet. I'm impatient. For instance, a a strip of cardboard and some duct tape would temporarily solve your redecorating issue if it was my shop.
chris1956
Post by chris1956 on Mar 27, 2024 19:58:34 GMT -5
Thank you goldfinder and chris1956 ! That's interesting you say that, the buff at my rock club says explicitly to use it dry. I don't think I've ever seen them recharge it either. As a result I've also done it try. I personally mixed my super cerium with water to create my own paste, and then applied that to the wheel and waited for it to dry. Not long enough, because it proceeded to spray a dividing line through my workshop on the floor walls and ceiling. But that was the intention anyway. 😆🤦♂️🤷♂️ I think you might be right. I have used the felt? "wheel" on my cabber wet. It has been so long, I may have buffed them dry on the buffer. I do remember it didn't take long to heat up a rock while buffing.
iamchris
Post by iamchris on Mar 27, 2024 22:48:42 GMT -5
iamchris I never claimed to know what I'm doing either. There's a new cerium technology I'm becoming vaguely aware of that calls for dry polishing on special disks. Maybe that's what your club is using. Somehow I got it into my head you were using cerium on a muslin buff, the stitched kind used for metal polishing. What material is the buff on your personal machine made of? I bought a super cerium resin wheel for my Genie. I've used it both wet and dry and so far all it does is ruin the polish I already have from previous steps. I know I'm probably using it wrong but as a friend says, everything's easy once you know how. I'm not there yet. I'm impatient. For instance, a a strip of cardboard and some duct tape would temporarily solve your redecorating issue if it was my shop. Maybe I should consider my software engineer mantra of RTFM for rocks... Made of the best grade wool felt, highly compressed into disc shape. 1/8in. thick to be used on face plate, flexodiscs, etc. Use wet with your polishing compounds: tin oxide, cerium oxide, linde A, etc
Post by liveoak on Mar 28, 2024 7:01:50 GMT -5
I have a KN cabber, so my end flat disc is inside my unit, but still, having my cabber in my studio (spare bedroom) I greatly try to limit how much mess it all makes.
I found that these "crayons" of Battstik work really well and don't really make a mess (well, the green chrome oxide one can't help itself). Basically like I said it's a crayon, I mist my wheel with a spray bottle, then turn on the machine, and rub the crayon on the wheel & you're good to go, no slurry to mix. Then I use the spray bottle as needed. As others have pointed out, polishing is supposed to happen as it starts to dry (and starts catching on the wheel in my experience).
The other thing I do to avoid the mess is using pieces of plexiglass to contain the water.
With your wheel outside your cabinet, you need to make some kind of extension to do that.
Shouldn't be too bad to come up with something that works.
Patty
Post by rockjunquie on Mar 28, 2024 7:27:56 GMT -5
rockjunquie perhaps I'm misusing the term. Sure looks like a [wagon] wheel, but I didn't want to confuse the terminology with a soft resin wheel. BTW this is one of the things that drives me bonkers about the HP CB8. Why it couldn't have been 1 inch longer to catch the spray is beyond me. My workshop would have a much smaller dividing line. And those red covers are a pain to put on. Wish I went with the KN8. rmf thanks for the info gemfeller I'm not pretending to know what I'm doing. There's a two wheel polish machine at the Rochester Lapidary Society that has 50k diamond on one side and cerium (presumably super cerium since it's white) on the other side. It has a paper sign saying to never spray water on it so I thought that's how it was supposed to be done. I'll inquire next time I go to see why they're of the opinion that it should be done dry. There's a good chance I used too much. And good call on taking breaks to avoid cracking. Confirmed, it's a con, not a pro if I can simply peel the stone off the dop or if it burns my hands like it has in the past, haha. Would it also be considered smarter to keep the stone closer to the center of the wheel to keep the wheel speed (i.e. heat) lower? Ok, It's your right hand flat lap. I call mine spin ons because... well... they spin on. I don't know if yours does. Can you swap out the laps?
iamchris
Post by iamchris on Mar 28, 2024 8:03:57 GMT -5
Post by rockjunquie on Mar 28, 2024 8:27:28 GMT -5
I have a lot of spin ons. If I had to do it again, I would have gotten the metal plate and magnetic laps.
iamchris
Post by iamchris on Mar 28, 2024 11:43:10 GMT -5
I'm tired of the polish getting in porous surfaces. I'm almost definitely going to get either Nova wheels or SuperNova wheels. I'm not so sure what the 2x price premium gets someone for Nova wheels. If it cabs more quickly and lasts as long, I'd be happy to pay it for as infrequently as they need to be replaced.
I've also seen CurrentlyRockhounding make his own belts, and there's no way they should cost $200-$240 per 8 inch wheel, so I'm hesitant to support such a price difference.
Post by rockjunquie on Mar 28, 2024 11:54:31 GMT -5
I'm tired of the polish getting in porous surfaces. I'm almost definitely going to get either Nova wheels or SuperNova wheels. I'm not so sure what the 2x price premium gets someone for Nova wheels. If it cabs more quickly and lasts as long, I'd be happy to pay it for as infrequently as they need to be replaced. I've also seen CurrentlyRockhounding make his own belts, and there's no way they should cost $200-$240 per 8 inch wheel, so I'm hesitant to support such a price difference. The higher polish Nova wheels will last forever. My 14 k lasted at least 10 years. Higher grits even longer.
iamchris
Post by iamchris on Mar 28, 2024 12:05:07 GMT -5
