iamchris
Member since June 2023
Post by iamchris on Mar 27, 2024 18:54:34 GMT -5
I've been struggling with my obsidian game tiles. I'm also rerunning some obsidian through from a previous batch that came out slightly hazy as some larger pieces as there aren't enough game tiles to fill a tumbler. 1. ran it through my vibratory for final 3 stages, came out hazy 2. went conservative and put it in my 33B for 120/220 through polish, finishing with regular cerium, came back out hazy 3. ran it through my vibratory once again at 120/220, this is where I'm at With this picture I see these scratches on some of the larger pieces after 120/220. I don't think these should be here after 2 days in 120/220, then rerun again in 120/220 for 2 days. I can't feel them, but they sure are visible. Before I move them on, I'd like the experts' opinions on whether I should be running these back through 80 to remove these scratches. Most pieces are smooth and matte, but these more severe ones have me worried that I'm going to have yet another failed run. Would love your thoughts!
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Mar 27, 2024 18:58:12 GMT -5
I'd put them in 80 for a week.
titaniumkid
Post by titaniumkid on Mar 27, 2024 19:16:38 GMT -5
That is heartbreaking. The shape is so nice.
hypodactylus
Member since July 2021
Post by hypodactylus on Mar 27, 2024 19:38:15 GMT -5
If you are referring to the shiny marks on the rocks, those are not scratches. Looks like you are using a metal colander/sieve and it is leaving marks on your rocks.
They will go away during the next tumbling round. Just be sure to not use a metal colander/sieve after the polish stage.
Post by jasoninsd on Mar 27, 2024 19:54:17 GMT -5
If you are referring to the shiny marks on the rocks, those are not scratches. Looks like you are using a metal colander/sieve and it is leaving marks on your rocks. They will go away during the next tumbling round. Just be sure to not use a metal colander/sieve after the polish stage. Nice deduction! That's exactly what those looks like...
chris1956
Member since July 2022
Post by chris1956 on Mar 27, 2024 20:04:01 GMT -5
Agree with others about the "scratches". Your game tiles in the second pick look really good.
ronnsrockroundup
Hurry up and wait.
Member since October 2023
Post by ronnsrockroundup on Mar 27, 2024 20:16:10 GMT -5
I'm not sure what filler you use for polish stage, but the .20 g airsoft pellets at a 50/50 ratio works great for my rotory obsidian polishing (the pellets don't float like the other plastic beads you find out there). Tried to polish in UV 10 a few times but had much less bruising and great shine from rotary. Stage 1 ROTARY, UV stage with ceramic 2 and 3 and back to rotary for polish using rock shed ao. polish and airsoft bb's. Working great for me. Hope this helps.
Post by Son Of Beach on Mar 27, 2024 21:48:17 GMT -5
That is heartbreaking. The shape is so nice. Wait till you get old.
Post by hummingbirdstones on Mar 27, 2024 22:36:14 GMT -5
iamchris
Post by iamchris on Mar 27, 2024 22:42:27 GMT -5
If you are referring to the shiny marks on the rocks, those are not scratches. Looks like you are using a metal colander/sieve and it is leaving marks on your rocks. They will go away during the next tumbling round. Just be sure to not use a metal colander/sieve after the polish stage. Well I feel dumb! I always thought the screen would be a softer metal. I suppose not, or the obsidian is softer than most? The screen came from The Rock Shed so that's a bit surprising. Either way, thank you for the easy solution!
titaniumkid
Post by titaniumkid on Mar 28, 2024 0:04:49 GMT -5
That is heartbreaking. The shape is so nice. Wait till you get old. Not sure what the cutoff is for old, but I'm not young. Anyway, things to look forward to It's great there's an easy solution to the scratches.
wyorock
Post by wyorock on Mar 28, 2024 7:45:02 GMT -5
I agree with the metal colander theory. It took me awhile to figure out I was leaving marks on my rocks with the brass hose nozzle I was using to wash them with. I don't use metal anything anymore except a pick to remove ceramic media from "tight places" in tumbled rock.
Post by HankRocks on Mar 28, 2024 8:20:08 GMT -5
Question, are they scratches or are they marks. If they marks I would not worry about them, they will go away. Most rocks are harder than metal. I have been using a metallic wire colander to wash my rocks out for years and have never seen a scratch Including twice after polish, the polish run and the after polish soap run with no marks. Is this the first time using the colander? if so maybe it's a coating of some sort on the colander that is coming off and will eventually be worn off. I believe jamesp polishes his glass pieces in a metal hopper he built and they come out great. Henry
Post by HankRocks on Mar 28, 2024 8:28:59 GMT -5
Question, are they scratches or are they marks. If they marks I would not worry about them, they will go away. Most rocks are harder than metal. I have been using a metallic wire colander to wash my rocks out for years and have never seen a scratch Including twice after polish, the polish run and the after polish soap run with no marks. Is this the first time using the colander? if so maybe it's a coating of some sort on the colander that is coming off and will eventually be worn off. I believe jamesp polishes his glass pieces in a metal hopper he built and they come out great. Henry Just went out into the garage and tested a piece of polished Brazilian Agate with a dental pick, I could not scratch the agate no matter how hard I applied the pick to the surface of the rock. That is different that applying the pick at great force into the rock, it could be chipped but that is a result of the force applied. That's how rock chisels work on rock outcrops, a tip of the chisel applied with great force will damage and eventually crack a rock.
hypodactylus
Post by hypodactylus on Mar 28, 2024 10:08:48 GMT -5
Question, are they scratches or are they marks. If they marks I would not worry about them, they will go away. Most rocks are harder than metal. I have been using a metallic wire colander to wash my rocks out for years and have never seen a scratch Including twice after polish, the polish run and the after polish soap run with no marks. Is this the first time using the colander? if so maybe it's a coating of some sort on the colander that is coming off and will eventually be worn off. I believe jamesp polishes his glass pieces in a metal hopper he built and they come out great. Henry They are marks, not scratches. The metal colander is not scratching the obsidian, just leaving streaks; sort of like a pencil.
