rockbrain
Member since January 2022
Post by rockbrain on Mar 28, 2024 19:14:18 GMT -5
These are my new pendant display stands. They're similar to some I showed on here before. The old ones were covered with vinyl that I couldn't get to stay on. These are sprayed with rock textured spray paint. I also made the front pieces on this much more carefully. All the holes are in the same spots so they're all interchangeable. I load all my pendants up at home, wrap a piece of stretch wrap around them and drop them in the bottom of a divided black plastic box. When I get to the sale I just have to take them out, unwrap them and run one screw in each side. These are also one tier taller than the last ones I made and I progressively slanted the front pieces so the bottom ones are more of an angle pointing up at you and the top ones that are closer to head height are closer to level. These also have a top section that is removable so they can be three tiers or four tiers tall. I also made a cabochon display case. It's wood frame with a plywood back. Inside the plywood is a piece of stone painted sheet metal. The bagged cabochons hang with a magnet. I can load everything up, close the case and transport it. It all worked out very well. I had to set up by myself for a show last weekend and it went very quickly.
rockbrain
Post by rockbrain on Mar 28, 2024 19:28:28 GMT -5
Post by realrockhound on Mar 28, 2024 20:02:20 GMT -5
Pretty nice. Look sharp
chris1956
Member since July 2022
Post by chris1956 on Mar 28, 2024 20:16:32 GMT -5
Wow! Very organized!
Post by jasoninsd on Mar 28, 2024 23:12:09 GMT -5
Post by liveoak on Mar 29, 2024 6:33:22 GMT -5
Looks great !
Patty
Post by rockjunquie on Mar 29, 2024 6:41:03 GMT -5
Those are great! Are they your own design? How long do you think they will hold up?
rockbrain
Post by rockbrain on Mar 29, 2024 9:02:17 GMT -5
Those are great! Are they your own design? How long do you think they will hold up? Yes, they're my design. I think they will hold up well. The stone paint seems pretty good and they don't really get much stress on them. When they are wrapped with the stretch wrap that pretty much keeps anything from moving or rubbing in transit. The sides will probably get scratched up a bit but they don't really show when set up. I made them flat black which isn't as tough as gloss but easier to touch up. I think if the front platforms get dinged up they can just be touched up to. The finish is bumping enough so it should just blend right in. I have a few pieces of carboard cut to size. I just throw another on the side pieces in the storage box and I can set my Riker cases and signs on top. I'm trying to get everything so I can do one load on my convertible hand truck/cart. It probably won't happen just because my awning is so large and I can't really do anything about that. Everything else will go in boxes and my 4 tables, 2 chairs and all the boxes can go on one cartload. The awning does have wheels.
Post by rockjunquie on Mar 29, 2024 9:09:19 GMT -5
Awesome! Sounds like you got it down to a science. Your design is really cool. I like the use of textured paint.
khara
Member since September 2022
Post by khara on Mar 29, 2024 11:12:48 GMT -5
I like it, looks very sharp!👍
Post by agatewhisperer on Mar 29, 2024 21:38:30 GMT -5
Love it. I'm always looking for better ways to transport and set up/ take down.
