nolasean
Member since March 2024
Post by nolasean on Mar 30, 2024 20:09:29 GMT -5
I remember reading or hearing about running new ceramic media in a tumbler to soften the edges. Can someone elaborate on this? What type of tumbler, grit, length etc... Thanks
titaniumkid
Member since June 2023
Post by titaniumkid on Mar 30, 2024 23:07:23 GMT -5
If you already have rocks tumbling in medium grit, you can add the ceramic media to that, which will wear off any hard edges. You could also run it separately from the rocks in coarse or medium grit for a few days.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Mar 31, 2024 6:59:43 GMT -5
You can start it Mixed with rocks in 80 grit or 220 grit then move it along with the stones to finer grits. Once I get a batch in polish I keep it to reuse it with polish. It will last a very long time in the pre-polish/polish stages. No need to run it by itself.
Post by victor1941 on Apr 1, 2024 8:26:56 GMT -5
I mix it(new) in the first and second run in the Uv-18 vibe and when finished keep it separate as filler. Start the next cycle with new media and fill with rounded media.
