choochoorocks
Rock hounding
Member since April 2020
Post by choochoorocks on Apr 15, 2024 1:02:05 GMT -5
Hi guys, I just got a used Lortone Qt66. It seems to run fine for a while, but after a few hours starts to make a squeaking noise. Then after several more hours, it stops turning the barrels and just hums. Picking up one barrel, I see that the shaft driven by the motor isn't turning. Any suggestions on how to troubleshoot this?
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Apr 15, 2024 16:41:41 GMT -5
Did you try tightening the belt?
Post by miket on Apr 15, 2024 20:04:23 GMT -5
Start with tightening the belt and clean off the shafts. Lubricate with a little oil. These are just places to start...
Post by Fossilman on Apr 20, 2024 10:46:00 GMT -5
Might have to change out the plastic bearings on shafts, belt might be loose.. Has to be sitting on level table..
