Mark K
Member since April 2012
Post by Mark K on Apr 18, 2024 20:07:01 GMT -5
Mark K
Post by Mark K on Apr 19, 2024 15:57:44 GMT -5
It is currently in the process of becoming a sphere.
Post by realrockhound on Apr 19, 2024 16:03:21 GMT -5
Honestly… I almost think that’s vistaite. Some sections in there that make me think it is. Colors are right as well. That things fractured to all hell though, will it hold up once you start drilling it down?
Mark K
Post by Mark K on Apr 19, 2024 16:41:47 GMT -5
I am cutting it on the saw. The inside seems to be harder than woodpecker lips.
Mark K
Post by Mark K on Apr 19, 2024 16:46:18 GMT -5
If it is, I have a hell of an expensive rock I am cutting into little pieces. That cut is 4 inches across and the finished sphere will be about the same.
Mark K
Post by Mark K on Apr 19, 2024 22:39:21 GMT -5
One little spot chipped off in the cutting. Turn #3 would have removed it any way, but I will have to be careful with this one when I rough it out. May have to use the 30 grit pads to rough it out and hit the high spots with the grinder as I go until it is round. May stabilize it with cyanoacrylate too.
Post by realrockhound on Apr 19, 2024 23:10:37 GMT -5
I can post a pic later of some vistaite I have, that has some of the same colors and patterns. Then let me know what you think
Post by Rockoonz on Apr 20, 2024 9:22:18 GMT -5
I would agree that it resembles Vistaite, woodpecker lips and all. The folks at richardsons ranch told me they glued up their spheres even when they look solid, easier than trying to glue the chunk back on later.
Post by realrockhound on Apr 20, 2024 15:58:43 GMT -5
Vistaite.
Mark K
Post by Mark K on Apr 20, 2024 17:10:51 GMT -5
The preform is done. I need to clean it up good and run it through the dishwasher to get all of the oil out. Then it will sit aside until I build my stabilization set up.
johnthor1963
Cattle dogs rock
Member since June 2023
Post by johnthor1963 on Apr 21, 2024 17:31:24 GMT -5
lol woodpecker lips I like that. That’s some nice looking material can’t wait to see it finished. Thanks for sharing love the woodpecker lips
Mark K
Post by Mark K on Apr 21, 2024 18:39:33 GMT -5
Post by realrockhound on Apr 21, 2024 19:36:08 GMT -5
Seeing that. Not a doubt in my mind it’s vistaite
Mark K
Post by Mark K on Apr 24, 2024 18:28:57 GMT -5
I stabilized it using the acetone and superglue method and it took the 7 inch wheel like a champ. Now it is on the rough cups and it is running beautifully. I had it almost perfectly round with flat spots before it hit the cups.
quartzilla
Member since April 2020
Post by quartzilla on Apr 30, 2024 21:17:00 GMT -5
Mark, can’t wait to see how it comes out. Could be legendary!
wargrafix
Member is Online
Post by wargrafix on May 1, 2024 8:35:51 GMT -5
Mark, it.sure is pretty
