chaosdsm
Member since April 2024
Post by chaosdsm on Apr 22, 2024 23:08:22 GMT -5
My Nat Geo Pro 3-speed & Lyman Vibratory Tumblers Yes, that is a brass tumbler, but it has a donut bowl, no drain to worry about plugging, 11lb capacity, and at $100 I couldn't pass it up! I don't like the lid though, very thin & bows in very easily, not that I'll need the lid for anything other than keeping dust and insects out. Also picked up a Vevor 11lb/5Kg Jewelry Tumbler. This one is direct drive... no external belt to break!!! All 4 wheels that contact the drum rim have teeth in them to drive the drum! Seems to work okay, waiting on a shipment of Labradorite from rock shed to test it out!!! Though I did already do a 4 hour dry run with 4lbs of ceramic media to remove the gloss on the inside of the drum which is why you cannot see into it. And a stock pan.... for making my own flat lap machine It's 11.5" wide, so large enough to run wheels up to 10", and stainless steel, so no worries about rusting! I have a couple of DC motors laying around & plan to run it off solar / battery power!!! NOT lapidary related, but I was inspired by the macro photo thread, & picked up a digital microscope! It allowed me to get this extremely close shot: Which is part of a bears eye on the back of the Alaska State Quarter:
khara
Member since September 2022
Post by khara on Apr 23, 2024 1:53:40 GMT -5
I hope you’ll post your flat lap build. Sounds interesting. And, are you SURE the digital microscope isn’t lapidary related? I’d be seeing what kinds of rock photos I could get with that.🤓
chaosdsm
Post by chaosdsm on Apr 23, 2024 12:23:16 GMT -5
are you SURE the digital microscope isn’t lapidary related? Indirectly related for sure! But I'll be using it for all kinds of stuff. Already found an error coin with it, but unfortunately it's a minor & common error so no real added value. Will definitely post the flat lap once I get it done, but that will probably be months down the road....
Post by jasoninsd on Apr 23, 2024 13:13:24 GMT -5
Congrats on the new "tools"!! That digital microscope is super cool!!
JR8675309
Member since August 2019
Post by JR8675309 on May 15, 2024 7:01:06 GMT -5
YOUR digital microscope is better than MY digital microscope... waaah!!' I thought I was the only one doing that, clearly I e missed a channel. What is the model? Edit: I see the model on the booklet... now I must find one!!
