Post by liveoak on Apr 23, 2024 6:24:11 GMT -5
I figured before I started on my first piece, I'd see if anyone had any tips I might need to know.
Most of my searches on the forum seem to be about tumbling, and I don't have a vibe.
Any thoughts or concerns I should be aware of ?
Patty
gunsil
Member since January 2023
Post by gunsil on Apr 23, 2024 7:24:17 GMT -5
I have cabbed tiger eye and found it just like any other agate. Takes a great polish easily.
Post by liveoak on Apr 23, 2024 8:01:27 GMT -5
That sounds too easy gunsil - thank you
NDK
Post by NDK on Apr 23, 2024 9:57:04 GMT -5
One thing to be mindful of is sometimes the fibers can be a little loose (I've found this more in the blue variety). When grinding watch if they're pulling out and if so work accordingly, grinding/sanding towards the end of the fiber.
Post by realrockhound on Apr 23, 2024 10:18:46 GMT -5
I cabbed some blue tigers eye a while back. Stuff was soft as all hell. Was getting flat spots on 3000. No clue if that’s typical of the material
gemfeller
Member since June 2011
Post by gemfeller on Apr 23, 2024 14:18:13 GMT -5
Some folks are terrified by the fact Tiger's Eye is silicified asbestos. They mask up. If that's a concern, do it. Some material does have loose fibers as realrockhound mentions. I avoid that type, and it's pretty easy to identify. Meanwhile, I've cut dozens upon dozens of TE cabs easily and with no problems at all.
Post by rockjunquie on Apr 23, 2024 18:33:39 GMT -5
Some folks are terrified by the fact Tiger's Eye is silicified asbestos. They mask up. If that's a concern, do it. Some material does have loose fibers as realrockhound mentions. I avoid that type, and it's pretty easy to identify. Meanwhile, I've cut dozens upon dozens of TE cabs easily and with no problems at all. I must be unlucky because probably half of the ones I've cut tended to pull fibers. I have two preformed (one marra mamba) and I hope that they are problem free.
gemfeller
Post by gemfeller on Apr 23, 2024 19:30:52 GMT -5
Some folks are terrified by the fact Tiger's Eye is silicified asbestos. They mask up. If that's a concern, do it. Some material does have loose fibers as realrockhound mentions. I avoid that type, and it's pretty easy to identify. Meanwhile, I've cut dozens upon dozens of TE cabs easily and with no problems at all. I must be unlucky because probably half of the ones I've cut tended to pull fibers. I have two preformed (one marra mamba) and I hope that they are problem free. Usae a 10-X loupe to inspect the rough. You can usually tell if it's "problem" material. Marrra Mamba's a little different than South African TE. It does tend to have looser fibers in some instances I've found.
Post by rockjunquie on Apr 23, 2024 19:32:40 GMT -5
I must be unlucky because probably half of the ones I've cut tended to pull fibers. I have two preformed (one marra mamba) and I hope that they are problem free. Usae a 10-X loupe to inspect the rough. You can usually tell if it's "problem" material. Marrra Mamba's a little different than South African TE. It does tend to have looser fibers in some instances I've found. Thanks!
Post by liveoak on Apr 23, 2024 19:50:23 GMT -5
Thank you, everyone, for weighing in.
I'm guessing strong magnification, so I know what I'm working with will help, that and paying attention.
At the moment I'm not jumping to try the blue Tiger Eye I have, I think I'll start with the regular to get my feet wet.
With any luck, I'll be able to show some good results.
Thanks again for the input.
Patty
Post by liveoak on Apr 26, 2024 9:50:35 GMT -5
No problems-life is good, today I did mask up for pre-forming & grinding, as I figured that was the most exposure time.
But otherwise nothing much different that good magnification didn't keep me zeroed in on.
I LOVE the way it glows in the morning sunlight.
I gotta do me some more.
Thanks, Randy, RWA3006 for the slabs Patty
Post by rockjunquie on Apr 26, 2024 9:52:19 GMT -5
Great job! I love the golden stuff. Very pretty.
Post by liveoak on Apr 26, 2024 10:42:07 GMT -5
Thanks Tela
Post by RWA3006 on Apr 26, 2024 17:42:39 GMT -5
Tiger eye is one of my favorites.
Post by liveoak on Apr 26, 2024 18:46:24 GMT -5
Beauties
Patty
