Post by rockyraccoon on Sept 14, 2004 10:26:56 GMT -5
i've had my 2 barrels on one of my lortone qt66's stop rolling twice recently. both times taking the barrels off and putting them back on corrected it. i oil regularly and am stumped as to what is causing this unless i have overfilled them. is there anything i need to check? i'm not mechanical so give me kindergarten level advice if it's very technical . it's been rolling for 8 mos. straight now and i've never had any problems before. but if there's a problem i'd like to get it corrected now before i burn the motor out. kim
Post by BIRDSEED on Sept 14, 2004 12:44:11 GMT -5
USUALLY THAT PROBLEM IS DUE TO OVERLOADING-TOO MUCH WEIGHT-THE MOTOR AUTO-SHUTS DOWN..HAVE HAD THE PROBLEM MYSELF-AFTER A PAUSE AND TAKING OUT SOME STONES THE LORTONE WILL RESTART AND CONTINUE--HOPE THIS HELPS..
Post by krazydiamond on Sept 14, 2004 12:51:33 GMT -5
i've also had a similar problem, check your rollers, sometimes a little gunk will really increase the drag enough to slow or stop your barrels. and check your barrels, too, if there is anything sticky or gunky, how's that for technical?
KD
Post by sandsman1 on Sept 14, 2004 13:12:48 GMT -5
take the barrels off and wile its rollin take a clean rag and wipe the pulley groves and belt if it comes up with alotta black the belt could be slipping on the pulleys from the dirt or oil i noticed it happend to me after i had oiled the rollers i musta got oil on the pulley or belt and it kept stoppin till i cleaned the belt and pulleys
MichiganRocks
"I wasn't born to follow."
Member since April 2007
Post by MichiganRocks on Sept 14, 2004 14:21:02 GMT -5
Hey Kim, my Lortone occasionally does the same thing. Every three or four months, I take a piece of 600 grit sandpaper and littlely hold it against the rollers while it's running to take "the shine" off. I then do the same thing to the barrel. It's especially important to rough the barrel one it's been allowed to slide on the rollers as the surface will become shiny and glazed. I no longer have any problems.
Ron
Post by rockyraccoon on Sept 14, 2004 16:35:53 GMT -5
ok i used the sand paper on the rollers and barrels, took off the belt guard and yuck there was black gunk all on the right side of that thing which might have been slowing the belt down. i cleaned that good. but i do have one more question. how would i know if the belt was too loose??? it seemed ok to me but that's because it hadn't fallen off and was moving ;D. and where is this adjustment nut?
kim
Post by rockyraccoon on Sept 14, 2004 16:38:12 GMT -5
oh and i moved the barrels to the other qt66 and swapped the ones that were a little lighter over. the heavier ones are rolling fine on the other one so i'm inclined to think its this tumbler. it seems to be going a little slower than the other tumbler though they are just alike.
kim
Post by sandsman1 on Sept 14, 2004 16:52:16 GMT -5
kim just losen up the motor nuts and slide the motor to tightin the belt but dont make it too tight they should have some play in the belt when you push on it,, i leave my belts so loose you can take them off without unscrewing the nutts on the motor
JKowalski33
Member since August 2004
Post by JKowalski33 on Sept 20, 2004 20:43:29 GMT -5
why does the bottom of the lortone 3# barrels become concave after a few days? is this just signs that there isn't a gas build-up?
Post by rockyraccoon on Sept 20, 2004 21:44:21 GMT -5
jackson that's what mine does when there is gas - suck the bottom of the barrel inward and i'm assuming at some point if i don't release the gas it goes the other direction and blows the top off.
update on my stopping barrels - they stopped again after i had sanded the rollers and barrels so i moved the motor by loosening that top nut and moving the motor over to the right a little. it made all the difference in the world and it is rolling at the correct speed again. thanks everyone for helping me with that. without your input that tumbler was doomed because i would never have figured that out.
kim
shorty
Member since December 2003
Post by shorty on Sept 20, 2004 22:20:26 GMT -5
hi kim i have a loritone 33 and when i oil it to mutch the oil wil run through the barines and go to the belt and make it slip that is probably is that gunk on the belt you said you see that mite be whats making it slip. when myne slipes thats usually is the problem hope that will help you.shorty
shorty
Post by shorty on Sept 20, 2004 22:27:18 GMT -5
kim if i were you i would just clean the belt.... rather than titen it ..and try then if it still does stop again then tighten .
Post by rockyraccoon on Sept 20, 2004 22:32:32 GMT -5
when you say clean the belt shorty do you just wipe it off? do you take it off to clean it?
kim
shorty
Post by shorty on Sept 20, 2004 23:00:37 GMT -5
i roll the belt off and use a mild laundry soap and clean and rinse with warm water the belt and puleys off and the rollers where it is cuming on the pulleyand sometimes oil will get on the rolers clean them to
Post by connrock on Sept 21, 2004 5:16:40 GMT -5
JKowalski33,, The bottom of the barrel gets an inward look (concave) because of vacuum from the rocks cooling. If it was a gas problem the barrel would bulge out or the lid would loosten or maybe even pop off. Some people heat the barrel and rocks in hot water to make sure a vacuum is created whick creates a very good seal. This technique will only work on Lortone "type" barrels.It doesn't work very well on barrels such as the Thumlers Mod B which are constructed differently. Tom
Post by creativeminded on Sept 21, 2004 9:03:01 GMT -5
I just recently had that problem happen to me and it was because my belt got stretched out, I got a new belt and my problem was solved. Tami
JKowalski33
Post by JKowalski33 on Sept 21, 2004 17:04:02 GMT -5
so is the concave effect a good thing then tom, like does is aid to the grinding process or something? or should open the barrels to remove the vacuum...?
duke
Member since May 2004
Post by duke on Sept 21, 2004 19:13:49 GMT -5
I had the same problem as creativeminded and a new belt fixed the problem. Evidently, my old belt had stretched too much and even tightening the belt all the way didn't help.
Post by puppie96 on Sept 22, 2004 1:37:11 GMT -5
I don't think the vacuum hurts anything.
