phoenix1647
Member since March 2013
Post by phoenix1647 on Sept 27, 2004 11:36:12 GMT -5
Hello..I am Pho, a new member from Texas. I have just finished running the polish stage for the second time on a bunch of rocks of mixed hardness. Both times a few of the rocks (I think some are rosequartz but not sure of the others) are coming out with scratches. All of the road rock/river rocks polished just great. I had 6 large Apache tears in there as well and they did not polish but did come out with scratches on them. Any suggestins? I had the barrel a little over 1/2 full (3 pounds) with just water and polish in it and ran for 7 days each time.
birdseed
Member since September 2004
Post by birdseed on Sept 27, 2004 13:03:26 GMT -5
1. Did you use plastic pellets?.. 2. Sounds like you have hard and soft stones mixed(no no) 3. Did you run a a good pre-polish?--maybe you need a 1000 grit stage... 4. Experiment
bwalters
Member since March 2004
Post by bwalters on Sept 27, 2004 16:36:21 GMT -5
Hi Pho, Welcome to the board! What part of Texas are you from? I'm a Texan, too, all my life.
Sounds like Birdseed's advice was right. You definitely need to use pellets when polishing, and shouldn't mix rocks of various hardness.
Hope to hear more from you.
BE
phoenix1647
Post by phoenix1647 on Sept 27, 2004 17:52:34 GMT -5
Hello birdseed and bwalters.. Yess..I do have hard and soft rocks mixed....could have been what the problem is. Yes..I do have the plastic pellets in there too. bwalters..I am from close to College Station,,,,near Lake Somerville. I am running the stones again in a pre-polish....but only the ones that were scratched up...see if that helps.
Thanks for your quick response..I do apprreciate all the help I can get..
Pho
bwalters
Post by bwalters on Sept 27, 2004 19:00:28 GMT -5
Pho, Are you using pellets in your prepolish stage, too? And what grit are you using for prepolish? I'm still learning also so appreciate all the info I can get!
I live in Medina, Texas, the "Apple Capitol of Texas", in Bandera County, the " Cowboy Capitol of the WORLD". Surely, you've heard of us!!! HAHAHA! Medina is only 'famous' one day of the year when we have our Apple Festival. Bandera County has produced 8 national rodeo champions, hence the county moniker.
Good luck with your stones!
BE
phoenix1647
Post by phoenix1647 on Sept 28, 2004 7:23:40 GMT -5
Not sure what size grit I'm using....it all came as a package with lables on it. I did use the plastic pellets in the pre-polish stage and polish stage both. I am running the apache tears and dthe gem stones again together as they both came out in the same condition. Can anyone recommend a good book for learning what rocks can be run together? I realy have no clue as to how hard a rock is...or which ones can or cannot be run together. Thanks
Post by Cher on Sept 28, 2004 11:54:02 GMT -5
Post by sandsman1 on Sept 28, 2004 13:34:50 GMT -5
Post by connrock on Sept 28, 2004 16:37:43 GMT -5
Hi pho and welcome to our group!! Here's a link that pretty much covers it all. Tom
Post by krazydiamond on Sept 28, 2004 16:59:12 GMT -5
Welcome, Pho! here is a link i recently found that is helpful, shame about the background, tho...makes it hard to read! www.gemworld.com/Info-GemAlpha.ASPsee ya on the board, KD
phoenix1647
Post by phoenix1647 on Sept 28, 2004 19:15:32 GMT -5
WOW !!!!!
Thanks for all the very helpful info guys......this realy helps me out. I appreciate each and every one of you responding like you have. If there is any way I can help you with something,,,,just let me know.
Pho
shorty
Member since December 2003
Post by shorty on Sept 28, 2004 19:51:45 GMT -5
hi pho those tears should come out and all the stuf that didnt take a polish sounds like there to soft for the harder stuf and the tears should be run seperate from the others finish the harder stuf then the soft they will all end up looking good and welcom to the bord im from michigan good luck shorty
shorty
Post by shorty on Sept 28, 2004 19:56:29 GMT -5
pho if you want to repay me just show some pic of the finished stuf shorty hahaha
Post by BearCreekLapidary on Sept 30, 2004 9:32:37 GMT -5
Hello Phoenix,
Looks like I missed saying "hello".
Welcome to the board.
As you are learning, there are some great people on this board. We are glad to have you join.
John
