Post by Cher on Oct 7, 2004 11:24:52 GMT -5
I checked mine, the Chicago Electric was 56 rpm and the Lortone was 40. I know there's another thread in here where faster rolling was discussed but who knows how far back it is or what the title of the thread was. It was a good thread that discussed the amount of water to use in the barrel too. I'll see if I can find it. [glow=red,2,300] ~ Cher ~[/glow] pages.prodigy.net/bestsmileys1/signs/RockOn.gif [/img]
69beeper
Member since August 2004
Post by 69beeper on Oct 8, 2004 10:09:24 GMT -5
56 rpm... let's see, that's 23,040 revolutions per day more than your 33B. There's a difference of 11,520 rpd between my two lortones. Don't know how much it matters, but if you add those #'s up over a 4-6 week tumbler run, there's quite a difference! Was this the thread you are talking about? Jimmy
Post by Cher on Oct 8, 2004 11:28:28 GMT -5
The thread I was talking about is back on page 6 and titled 120/200 2nd Stage Question. It was more about the problem I was having with grit stuck in the bottom of the barrel, but there was some discussion about how much water to use. [glow=red,2,300]Cher[/glow]
birdseed
Member since September 2004
Post by birdseed on Oct 11, 2004 13:27:38 GMT -5
Remember-a 4" barrell will rotate about 60 RPM at the most and a 8" barrell will rotate about 30 RPM- The larger the barrell the slower the RPM-- Concerning tumbling 1st stage at a higher speed--If the engineers at Lortone or Thumblers thought it was best to increase the speeds-they would have designed their equipment for that speed--Today's tumblers are the best engineered you can buy--Everyone looks for "short cuts"--This hobby requires patience...
JKowalski33
Post by JKowalski33 on Oct 21, 2004 19:36:46 GMT -5
i have 2 3A's and a 33B. both the 3A's are used and off ebay, and 33B is about 2 months old. The 3A's are slightly off speed, and the 33B is quite a bit slower. does any of you know why this might be? is slower bad? should i try to speed up the 33B and if so how?
deepsouth
He who rocks last rocks best
Member since January 2004
Post by deepsouth on Oct 22, 2004 3:51:30 GMT -5
Some info I have at hand regarding speeding barrels:
4,5" diameter should do 60 revs 6" 54 revs 8" 48 revs 10" 42 revs
I have just ordered 2 x 12 pound Lortone barrels and asked the speed question myself. My old supplier passed away 2 weeks ago and I only just heard about it yesterday. They gave me an address of a new supplier , who I found out, is the main importer of grits into NZ from USA. A very helpful person indeed in the town of Rotorua.
Good luck
Jack
birdseed
Post by birdseed on Oct 22, 2004 4:27:58 GMT -5
Some things improve with SLOW speed: 1. A fine cuban cigar and glass of kentucky striaght boubon whiskey. 2. A beautiful sunset on Florida's west coast. 3. Sex...............
JKowalski33
Post by JKowalski33 on Oct 22, 2004 16:32:22 GMT -5
are there anyways to speed up rpms? 60 a minute is 1 a second, and i know they arent going that fast, havnt actually counted for a minute though, i can just tell. what are some ways i can tweak it to speed it up?
Post by kayk on Oct 22, 2004 21:25:46 GMT -5
if you get a more powerful motor you could load your barrels without bothering for it's weight and increase your speed at the same time.
Post by Toad on Oct 22, 2004 21:29:32 GMT -5
Vibratory is much faster than 60 per minute.
Post by sandsman1 on Oct 22, 2004 21:37:41 GMT -5
JK someone i think it was ron said how to speed up a barrel what ya had to do was make the drive roller that the barrel sits on bigger and it would speed it up i played around with the idea ,, i used a heater hose for a car and slit it and wraped it around the bar it kepted slinding to one side and rubbing but it worked it did speed up the barrel,, then i tried duct tapeing a drive bar i think that worked alittle better on a lortone QT-12 but not a model-b but the tape will sooner or later start coming apart and it makes a mess so i took all the tape off and went back to normal hahaha,, it does work but i havent found a way to doit that will work for along time so if you do yell it out i wanted to have a way to speed up my three model-b-s i use for rough grind without buying the 3000 rpm motors
Post by cookie3rocks on Oct 22, 2004 21:51:58 GMT -5
Sands, we haven't seen any of your tumbled stone in awhile. Got Pics .cookie
Post by sandsman1 on Oct 22, 2004 22:20:03 GMT -5
cookie i had my tumblers shut down for the last couple months i had all this stuff runnin plus the air conditioner and when i got a 250.00 elec bill i pulled the plug on them in mid roll hahahaha-,, ill prob turn them back on in a few weeks think i sent the electric co. like 500.00 in the last two months hahaha so ill wait till im sure i dont need the air any more
