birdseed
Member since September 2004
Post by birdseed on Oct 19, 2004 3:04:33 GMT -5
What would you say is the normal life- span of a drill bit?--How many usages?? If you get a long life- span-What is your secret???
Post by sandsman1 on Oct 19, 2004 17:25:16 GMT -5
i think the most i have got from one bit was around 7 holes and that was drilling sodalite and acouple pieces of the red crazylace but the holes where in the softer part but the drill bit is still in the drill so who knows it might die next hole hahaha
Post by docone31 on Oct 19, 2004 17:28:19 GMT -5
That is why I use hardened copper wire and grit. It is way slower but the trade off in time vs., cost. I consider it worth it.
birdseed
Post by birdseed on Oct 20, 2004 4:54:29 GMT -5
Doc--more detail please!!!
Post by docone31 on Oct 20, 2004 9:08:39 GMT -5
There is a thread on the forum where I go into detail. Essentially it is wire that has been work hardened, chucked into a bit and turned into the stone. The grit is made into a well and the drill/copper wire, is lowered into the hole, and recharged with grit. The wire wears away with the drilling but the new wire keeps the hole diameter. It takes learning the touch but I think it is worth it.
