doit4luv
Member since September 2004
Post by doit4luv on Nov 1, 2004 0:02:38 GMT -5
I would like some suggestions regarding tumbling Obsidian as it pertains to the following:
Do you need to use filler material such as plastic pellets in ALL of the tumbling cycles?
What is the best type of polish to use with Obsidian? I've read varying outcomes with Tin Oxide.
As always, thanks in advance for your input.
Banjocreek
Member since March 2003
Post by Banjocreek on Nov 1, 2004 0:22:01 GMT -5
My humble opinion is as follows: 7 days in 60/90 no pellets 5 days in 120 with standard amount of pellets 5 days in 500 again std amount of pellets. 4 days in 1000 ditto on pellets. 4 days in Tin Oxide I use 50/50 pellets to Obsidian. Whalla...
Post by Cher on Nov 1, 2004 0:36:32 GMT -5
Aww Banjo, you made me drool all over my keyboard again! ;D Those Apache Tears are so gorgeous!!
Cher
Banjocreek
Post by Banjocreek on Nov 1, 2004 0:48:42 GMT -5
You can run Obsidian in the 60/90 as long as you like, but it is a bit softer than a lot of stones so keep an eye on it. I think 14 days is the most I ever ran it. I have a lot of it out here in Arizona, so It seems I almost always have some in one tumbler or another. Good Luck!
Post by Cher on Nov 1, 2004 0:52:31 GMT -5
Banjo, Two questions ... Do you have an idea of what the hardness is of it? Do you ever mix it with anything else?
Cher
Banjocreek
Post by Banjocreek on Nov 1, 2004 11:15:05 GMT -5
I think the hardness is 4.5 - 5. Someone can correct me if I am wrong. It is nothing more than volcanic glass, so what ever the hardness of glass is will get you in the ballpark. I may run it with other stuff but at the polish stage it goes solo. No mixing.
Post by krazydiamond on Nov 1, 2004 14:56:37 GMT -5
i ran a few barrels in 60-90 to get enough to go onto 2nd stage, some of the gnarlier pieces i ran 2 weeks in 60/90, tey got real small too. Banjo, those are SO pretty..... KD
JKowalski33
Member since August 2004
Post by JKowalski33 on Nov 1, 2004 19:52:48 GMT -5
this is just sorta a vague question on pellets. for example, do you fill the barrel with a little less then half rocks, then add pellets to bring the volume to between 1/2 to 3/4 full? or do you fill it 1/2 to 3/4 full of rocks, then add pellets on top of that?
Post by Cher on Nov 1, 2004 20:19:13 GMT -5
Good question, hope I'm not doing it wrong but I have mine about 2/3's to 3/4's full including rocks and pellets. I guess I figured you have to leave some room for the tumbling. I'd think if you have it full, it's not going to roll at all as the barrel is turning.
Cher
