Post by BuiltonRock on Jul 20, 2007 7:53:40 GMT -5
I have a Lortone arbor with the exact spand drum. www.lonniesinc.com/Products/Tools/Lapidary/lortone_max-pro_8C.htm , much older than the one pictured. It has a drum which divides into halves, then you replace the belt around a rubber ring, put the halves together and back on the arbor. I'm sure many of you know the procedure. I really do not like it as the belts do not run very smooth and it is slow to change. What is the best replacement drum for this type machine? Thanks for helping john
firewalker45
Member since August 2006
Post by firewalker45 on Jul 25, 2007 15:44:52 GMT -5
Hi John, the expando drum is pretty good. It takes a different size belt, so you will not be able to use your current belts. You can check them out at www.kingsleynorth.com Hope this helps. Daniel
Post by BuiltonRock on Aug 2, 2007 10:21:33 GMT -5
Thanks Firewalker, I did just that and I love it! john
firewalker45
Post by firewalker45 on Aug 2, 2007 17:22:39 GMT -5
Hi John, glad I could help. Yes it is so much nicer to just slip on and off without taking the whole drum off. Daniel
