Glenn
Saw oil
Feb 27, 2005 21:54:53 GMT -5
Post by Glenn on Feb 27, 2005 21:54:53 GMT -5
I got my old" Dinosaurs" new to me saws on sat , Been busy cleaning them up . The 16" slab saw the oil was clean ,I had drained it to make it less weight .It cleaned up nice , Cuts Great , Agates any way ! The small saw was a different story . He must have used it alot more. it was a mess ! It's a10" the blade seems to cut good , but the resirvour was about full of junk .So I dumped the oil ! So what should a guy use ? Shell oil has two kinds ,Shell pella and shell Dialax ? Shell dialax has less missing . Next where to order from ? I also a got Crown vib tumbler any body know anything about that . And alot of rocks and much more ! It was agood find ! Thanks Glenn ;D ;D
RedwoodRocks
Member since March 2003
Saw oil
Feb 28, 2005 0:55:50 GMT -5
Post by RedwoodRocks on Feb 28, 2005 0:55:50 GMT -5
Hi Glenn,
I use Shell Pella in my 10" rock saw. There is almost no odor. I haven't used the other one - Dialex. From what I have read on Pella was that it was a grade below food-grade oil. I found it by calling petroleum companies in the phone book. The place I found sold it in 5 gallon pails and ran $8 per gallon. That was a couple of years ago. With the crazy gas prices lately, I would imagine the cost has gone up.
You can also recycle the oil. Get a 5 gallon pail and a brown paper grocery bag. Put the bag in the bucket and pour the oil and gunk into the bag, the bag acts as a filter. The oil will come out like new. I also use a piece of hardware cloth/chicken wire in the bottom of the bucket to hold the bag above the oil.
Cal
Saw oil
Feb 28, 2005 8:54:34 GMT -5
Post by mrbrett on Feb 28, 2005 8:54:34 GMT -5
I have a 20" slab saw and i use food grade mineral oil. It is about $5.00 a gal and to me it works super.
Saw oil
Feb 28, 2005 9:53:25 GMT -5
Post by creativeminded on Feb 28, 2005 9:53:25 GMT -5
Did you have a thick layer of oily residue on your saw, and how did you clean it up? I got a saw/grinder/buffer and the saw area has almost a 1/4 inch layer of old thick oily debrid and I have no idea how to clean it up. I have no idea what is in the resevoir. Tami
Glenn
Saw oil
Feb 28, 2005 11:48:52 GMT -5
Post by Glenn on Feb 28, 2005 11:48:52 GMT -5
thank 's for info ;D ! I found an oil dist. that has a oil that is equal to pella, he says ! he wants 6.00 a gal . I guess I will try that . the frieght off the web kills you ! I just used some unleaded gas to losen up the grime . then i spray starting fluid it clean it to a dry finish , then i sprayed it all with wd 40 ,it cleaned up nice ! How do you guys clean the oil off your cut pieces ? I guess you can put the piecs in some floor dry . thanks Glenn
Saw oil
Feb 28, 2005 13:09:21 GMT -5
Post by sandsman1 on Feb 28, 2005 13:09:21 GMT -5
glenn try some cheap kitty litter and fill a box or small tub and just jam the slabs in and they dry over nite
