phoenix1647
Member since March 2013
Post by phoenix1647 on Feb 28, 2005 13:09:22 GMT -5
This is a thing I made to use when I go rock/crystal hunting. If the soil is sandy or dry and loose, I can screen the material. Then when I get home..I can put my rocks on the screen and wash, sort or whatever....I also use this thing when I need to clean/change my tumbler barrels..works great..just dump the material onto the screen..wash it off with a hose and whalla...all ready for another load. It sure has come in handy. Just wanted to share that with you guys... This is a load of crystals I still have on it...sorting and cleaning them. Pho
Post by stefan on Feb 28, 2005 13:11:15 GMT -5
That is cool- BUT The Grass- Man your killin me!
phoenix1647
Post by phoenix1647 on Feb 28, 2005 13:11:31 GMT -5
I can't beleive I put this on the wrong board...ooops..
Pho
Post by Tweetiepy on Feb 28, 2005 13:35:30 GMT -5
Are you cleaning pony beads as well or is that the stuff you use as pellets? Nice colors - especially the green stuff on the ground - *sigh* I miss that - specially now that we're expecting another 10 inches of snow Waaaaaaaaaaaah My mom uses something similar to screen her pile of compost
phoenix1647
Post by phoenix1647 on Feb 28, 2005 13:47:56 GMT -5
Yes..I do use pony beads as filler....they seem to work well and are cheap...
Pho
(want I should send ya a box of grass to put on top of the snow?)
Post by Tweetiepy on Feb 28, 2005 14:33:58 GMT -5
Maybe just green spraypaint? ;D Or a huge hair dryer
Post by sandsman1 on Feb 28, 2005 14:41:04 GMT -5
hey pho i realy like that idea just dump your barrels on there and spray with the hose very cool
phoenix1647
Post by phoenix1647 on Feb 28, 2005 15:07:32 GMT -5
Sands..if ya wanna make one..it measures 2 ft by 4 ft and I used 1/4 inch screen. It gets a little heavy if you have to move it around a lot. When digging for crystals, I just shovel the material onto the screen...the dirt falls out and leaves the rocks and crystals..lot better than doing it by hand. I have it bolted together so I can take it apart, put it in the car and go on down the road, and it sits up in just a few minutes....
Pho
Post by Tweetiepy on Feb 28, 2005 15:17:52 GMT -5
You should add some wheels to lug it around like a wheelbarrow maybe?
phoenix1647
Post by phoenix1647 on Feb 28, 2005 15:52:30 GMT -5
Hmmm...not a bad idea..thanks.
Pho
Post by Cher on Feb 28, 2005 16:18:43 GMT -5
Big wheels, like the kind used on the back of some lawn mowers so it would roll easy. Very cool idea!!
Cher
Banjocreek
Member since March 2003
Post by Banjocreek on Feb 28, 2005 16:18:45 GMT -5
I really like that! But do you just move it around to avoid getting a big mud bog under it? Thats my problem, I use too much water and turn the yard into a swamp by the time I'm done dinking around. But that is a killer little set-up. I gotta do that.
Post by rockyraccoon on Feb 28, 2005 16:37:37 GMT -5
pho that's a great set-up! aren't you just the creative one.
kim
phoenix1647
Post by phoenix1647 on Feb 28, 2005 16:49:43 GMT -5
I move it around in the digging area to find more goodies.....and in the back yard when the area around it gets too soaked.... I recovered over 10 gallons of crystals in just a few hours with that thing...so it has paid for itself time and again. Thanks for all the compliments on that..it was just a matter of using something to recover more material....easier to use a shovel than a hand....
Pho
phoenix1647
Post by phoenix1647 on Feb 28, 2005 17:34:42 GMT -5
I might add that the 10 gallons I got in just a few hours was from their tailings....I have yet to go to the main mine..but will do so next time I go there...
Pho
Post by connrock on Feb 28, 2005 21:10:21 GMT -5
Hey Pho that's a unique set up you've made!! I use something very similar in the warm months but have to go through a fiasko in the cold of winter. Banjo,,,,, I use to use a lot of water too but have found that a very hard spray does the job using MUCH less water.I made a spray out of nozzles we use to use on the lube systems for the big drives we made way back when. They have a 1/8-27 male pipe thread and can be addapted to a piece of ss tubing.I use a 1/2" ball valve for a shut off and it's attached to a ss washing mach hose. If you want one send me your addy and you got it. tcknkk@adelphia.net Make sure you put rockhounds or something rock related in the subject box or I won't open it.I just got through curing my computer which had a terrible "viral infection"!! Tom
WarrenA
Member since November 2003
Post by WarrenA on Feb 28, 2005 23:45:31 GMT -5
could you post a picture of your wash nozzel?
Post by gaetzchamp on Mar 1, 2005 0:17:44 GMT -5
Ya, I'd love to see that hoser downer contraption too.
Pho-
One other great point about your setup that didn't get mentioned was the "back" saver. I've been dumping mine out in the gravel and spend 20 minutes or so bending down. This system lets you pretty much lets you stand in a natural posture. I'm sure doing the work you're doing, you're probably standing there for an hour or more.
thanks for the tip, I may have to rig one up.
Gaeter
Post by creativeminded on Mar 1, 2005 10:03:26 GMT -5
That is a very clever idea, thank you for sharing. the crystals you collect are they all the white or do you get some nice clear ones as well? Tami
phoenix1647
Post by phoenix1647 on Mar 1, 2005 10:50:13 GMT -5
Some are clear..some smoky...some white..just a big mixture of crystals in all shapes and sizes. They do tumble very nicely too.... When you tumble the clear ones..they will remain clear but will come out rounded.....they are like the prize in a crackerjack box..never know what ya gonna get...
Pho
