Post by stefan on Mar 8, 2005 15:43:59 GMT -5
Is this a good deal- and what is the difference between a horizontal lap and a polisher grinder?
The most complete and affordable exciting bargain to come along in years !! A complete diamond lapidary unit for grinding, smoothing and polishing. The name says it all - All -you- Need - for free hand working a wide range of materials including quartz, agate, topaz, moonstone, etc. Small and compact, this unit is ideal for those who have limited space.
Also, you’ll be pleasantly surprised at how clean and quiet this All-You-Need diamond unit is. Available in 6" and 8" models.
6" All-You-Need Outfit comes complete with:
Horizontal grinding unit with 1/8 HP variable speed motor, coolant reservoir and splash shield, 6" - 180 mesh metal bond diamond disc; 6" final polish pad; 14,000 diamond compound in syringe plus all necessary backing discs for the pads and diamond discs. Measures approximately 10" square by 8" high. Complete with operating instructions.
G2401
Shp.Wt 15 lbs.
$349.00
8" All-You-Need Outfit comes complete with :
Horizontal grinding unit with HP variable speed ball bearing DC motor; A coolant reservoir and splash shield; 8" - 180 mesh metal bond diamond disc; 8" - 325 mesh diamond smoothing disc; 8" - 1200 mesh diamond smoothing disc; 8" Final polish pad; Three 8" backing discs for the pad and diamond discs; Complete operating instructions. Measures approximately 14" square x 11" high.
G2402
Shp.Wt 20 Ibs
$449.00
from
www.jaderockshop.com/lapidaryequipment.htm
Just wondering if this is a way to get started?
G2401
Shp.Wt 15 lbs.
$349.00
G2402
Shp.Wt 20 Ibs
$449.00
from
