Post by stefan on Jan 12, 2006 14:30:17 GMT -5
I was having a lot of trouble with saw marks and such int the later stages of grinding- Sands gave me this little trick- Take a worn out 600 grit belt (sorry wheel fans but this just won't do it for ya) and run it dry- Shows the scratches you may have missed real well!
slim7309
Member since January 2006
Post by slim7309 on Jan 13, 2006 10:45:19 GMT -5
your doing something wrong -you skipping wheels trying to get done faster, Slim
Post by 1dave on Jan 9, 2016 7:54:24 GMT -5
Thanks stefan! John had a lot of great knowledge. Another tip is to have a florescent tube overhead. After each grind watch the reflection as you move the stone around. The curved surface magnifies the defects. Rotate the stone 90 degrees on the next finer stone until the previous scratches are gone, then rotate again and move on to the sanding belts.
Post by Tommy on Jan 9, 2016 11:23:25 GMT -5
Thanks stefan! John had a lot of great knowledge. Another tip is to have a florescent tube overhead. After each grind watch the reflection as you move the stone around. The curved surface magnifies the defects. Rotate the stone 90 degrees on the next finer stone until the previous scratches are gone, then rotate again and move on to the sanding belts. Haha sorry Dave but you get the prize for oldest thread pull up Nine years is a new record
Post by 1dave on Jan 9, 2016 11:48:27 GMT -5
Yeah Tommy, When John's threads disappeared from his profile, sandsman1, I started searching! Also, we don't have a section on grinding, sanding, or polishing. Or Faceting, so I had to make them up.EDIT: John's posts are back on his profile!
Post by nowyo on Jan 10, 2016 22:42:17 GMT -5
Necro-thread deluxe! Ya know, though, I spend a fair amount of time reading through old threads. There is some interesting stuff there.
Russ
Post by Fossilman on Jan 11, 2016 9:48:43 GMT -5
Education never stops....
