ArkieRockhound
Member since February 2005
Post by ArkieRockhound on Jan 24, 2006 14:59:27 GMT -5
I make a lot of Cabs and my eyes aren't near as good as they used to be. Just like Toby Keith, I'm not as good as I once was I kept checking my cabs for scratches and going through all six wheels and thinking --this one is going to turn out perfect, then I would take it in and check under another light, and, of course, right on top or on one side would be a scratch or rough spot. Then it would go back in the "do over" tray. Now, I go through the first three wheels, {I usually work on 20 or 30 at a time} Then I take them to a good light location, dry them real good and get out my magic marker. I paint every spot that needs a little more work. Then I go back and when I have ground out every bit of the marker, they are then ready for the last three wheels. It has saved me a lot of time and aggravation. I wouldn't use the marker on soft or porus rock or on a deep pit that you know will never grind off. If you do, it will be there forever. Hope this helps someone Trish
Post by sandsman1 on Jan 24, 2006 15:27:45 GMT -5
thats a good idea trish body and fender guys use flat black and hit in with a flat board and check for highs and lows
Post by stefan on Jan 25, 2006 11:07:13 GMT -5
Trish- Great idea- I tried it and it works!
Pebbles
Member since November 2005
Post by Pebbles on Jan 27, 2006 12:03:02 GMT -5
Great idea, Trish!
I know how hard it is to see some of those scratches, especially on a rock that has a lot of colors or patterns. I've also resorted to using a magnifying glass to inspect the rocks at various stages. It's time consuming, but time well spent in the long run.
Thanks for sharing your tip with us!
