<'))))>< Fish
Gone Fishing
Member since April 2005
Post by <'))))>< Fish on May 3, 2005 10:00:08 GMT -5
Question ?
Is it a good idea to grind rough stone then put in 60/90?
or is that a bad thing.
Dan
Post by Cher on May 3, 2005 10:25:18 GMT -5
Depends on if you want to shape it or not I guess. I've never done it before the 60/90 but I do quite a bit of shaping with my dremel in between 60/90 and 120/200 grits.
Cher
Post by krazydiamond on May 3, 2005 18:28:10 GMT -5
i often preform rock and then tumble it. heck, i've gone all the way through to polish on the grinder and then pop it in the prepolish stage in the tumbler cuz i wasn't 100% happy with it. sometimes it ruins the stone (undercuts it) but sometimes i've reached a good place with the stones. i don't think it matters how you get to where you want, as long as you get the desired result. well, at least when it comes to polished rocks! KD
Duckbean
Looking for rocks in all the wrong places
Member since February 2005
Post by Duckbean on May 3, 2005 22:25:22 GMT -5
I break a lot of my tumbling rock with a hammer and chisel, leaves a lot of points and such. Grinding them I think saves me a little time in 60/90. Bob
chassroc
Post by chassroc on May 4, 2005 12:48:39 GMT -5
Dan, As my friend Martha would say "That is a good thing". Preforming will only aid the Tumbling process. You can grind out around hollow areas to make them more accessable to grit and jumpstart the desireable rounding process essential to nicely tumbled stones. csroc
Voodoo Rage
Post by Voodoo Rage on May 4, 2005 13:45:17 GMT -5
I like to let it run at least a week an 45/70. That kind of gives you an idea of the general shape and layout of the rocks and exposes most imperfections.
<'))))>< Fish
Gone Fishing
Post by <'))))>< Fish on May 4, 2005 14:32:33 GMT -5
Well i put the grinder to use, and did about 2 pounds. Let see if they tumble faster.
Dan
