wayne
Member since May 2005
Post by wayne on May 20, 2005 9:10:30 GMT -5
I have been trying to find some vibra dry polish for several month with no success. anyone know a source for this polish. I have found it to be a great final stage polish.
wayne
Post by stefan on May 20, 2005 10:43:32 GMT -5
Sorry wayne can't help you there but welcome to the board. If the info is available I know someone here will be able to help!
Post by rockyraccoon on May 21, 2005 0:03:06 GMT -5
welcome wayne. can't help you find any vibra dry though.
kim
Post by sandsman1 on May 21, 2005 21:22:49 GMT -5
goldminer
Member since March 2018
Post by goldminer on Nov 15, 2018 9:10:15 GMT -5
VibraDry+ is a Diamond Pacific product. Is anyone using this stuff? Was thinking of trying it as the Alum. Oxide I now use is leaving residue in every crevice that is hard to remove.
hnhstngs
Member since September 2018
Post by hnhstngs on Nov 15, 2018 10:57:33 GMT -5
...the Alum. Oxide I now use is leaving residue in every crevice that is hard to remove. Was having the same issue until I started running a burnishing stage with just borax. Run it for a hour or so then add water to thin everything and run another 10 min or so before dumping. Now I get very little residue and what there is comes out easily with water flush and a toothbrush (just don’t let the stones dry out before you check them).
goldminer
Post by goldminer on Nov 23, 2018 21:29:08 GMT -5
Do you have any problems with the Borax dulling the finish of the stones?
NRG
Member since February 2018
Post by NRG on Nov 25, 2018 12:13:27 GMT -5
Do you have any problems with the Borax dulling the finish of the stones? All borax does is break surface tension. It makes the water wetter. Therefore it helps clean the cracks and voids.
hnhstngs
Post by hnhstngs on Nov 25, 2018 12:55:54 GMT -5
Do you have any problems with the Borax dulling the finish of the stones? Nope, they come out just fine. Shiny as I could want. I think the borax helps take that last thin film of polish off the stones that might dry to a haze otherwise.
Post by greig on Nov 26, 2018 22:07:38 GMT -5
I have also tried washing soda, baking soda and TSP. All seem to work for burnishing, but baking soda sometimes creates gas that needs to be burped from the tumbler (if burnishing for a number of hours). TSP might be overkill, especially when compared to Ivory soap or Borax. It might be interesting to mix some of these ingredients.
Post by johnjsgems on Nov 27, 2018 11:31:27 GMT -5
Vibra Dry is a Diamond Pacific product. I use Tide detergent for burnishig but did find soft stone polish dulled with burnishing. The Vibra Dry works very well and is a reusable product so cost decreases with use.
