adrian65
Member since February 2007
Post by adrian65 on May 17, 2008 8:52:24 GMT -5
Hi everyone, I made this cab from a Morissonite slab that I have from Tony - catmandewe, and then wrapped it in my groove style. front: back: and side: It's the first time when I work with morissonite, and I enjoyed it. Thanks again Tony for such great material! This is a surprise gift for someone, a friend of my mom. I hope she will like it. Thank you for looking, Adrian
indychris
Member since April 2008
Post by indychris on May 17, 2008 12:53:27 GMT -5
Looks FANTASTIC, Adrian! The shine on that thing is unbelievable, and the wrap sits perfectly in the groove with a nice low profile that shows the entire stone.
MidNight~Rocksi3
Member since January 2008
Post by MidNight~Rocksi3 on May 17, 2008 15:54:00 GMT -5
Gotta tell ya, those groove wraps are my favorite! very pro looking no doubt!
*smiles*
Post by sandsman1 on May 17, 2008 22:52:38 GMT -5
Adrian iv seen those kinda wraps befor but never knew how to get an even groove all the way around whats your secret -- cause i realy like the look -- that came out great
adrian65
Post by adrian65 on May 17, 2008 23:07:44 GMT -5
Thanks a lot folks! John, really no big secret, no laser guided or such Just a thin diamond blade. I firstly draw the line on the midle of the thickness of the cab and then I cut it (not very deep, I like the wire to pop a litle out of the groove). Here's the link about it: forum.rocktumblinghobby.com/?board=wwp&action=display&thread=22276&page=1Go to the 2nd page also to see some pics I'm sure you can do it, if you have the skill to do your fantastic edged cabs (by the way, I miss them) Adrian
Post by krazydiamond on May 18, 2008 8:49:09 GMT -5
that is slick, Adrian, i really like the way that looks.
KD
chassroc
Post by chassroc on May 19, 2008 12:04:37 GMT -5
That is a superior effort csroc
lsmike
Maxwell's demon lowers tumbling entropy
Member since January 2007
Post by lsmike on May 27, 2008 15:44:10 GMT -5
I haven't tried this yet but think it would work for making the groove.Mount your Dremel/Foredom in the drill press for it or a universal type vise with the working end down.Use Adrian's method or similar to make a secure water container.Adjust the height so the cutter is at middle of the cab edge and feed the cab around. As to cutters, the wheel bits would work, especially the ones with a convex profile as this would make a "V" that the wire[esp. square wire] could lie in.Also, I'm going to try diamond slitter discs-with these you can stack more than one on the mandrel if you need a wider groove.I have done the last for small-scale carving so it's like a mini "super grinder". If you have curves that are too tight for this,I'll bet you could go back with some kind of straight bit and close the gaps.My two cents,Mike.
