Post by sbreed on Jun 23, 2008 23:43:24 GMT -5
What kind of oil do I use for my Genie. It says I should put in a few drops of oil every week if I use it alot. Where can I get it?
Post by deb193redux on Jun 24, 2008 1:02:13 GMT -5
Something light like a drip oil. Standard 3M would work.
Post by sandsman1 on Jun 24, 2008 2:18:28 GMT -5
i use reg 3in1 oil and its been goin strong for a few years now
any hardware or bigger store ---- wal or k mart
Post by johnjsgems on Jun 24, 2008 10:12:26 GMT -5
The oil is for the pump leathers. You don't need to add until you notice the pump not pumping like new. Any light weight oil works fine. The motor is sealed and doesn't require any maintenance. If you have hard water and not cutting for a while remove the geysers and blow out th holes. Mine plug up and I have to clean out the hole with a small wire.
darrad
Member since September 2006
Post by darrad on Jun 26, 2008 19:36:18 GMT -5
I only use mine on weekends and have oiled the pump leathers only once in a year of use. I ruined the leather on a pump Coleman stove by oiling too much. It became soggy and would not pump pressure into the tank. I think they work pretty much the same way. As John said I do have to blow out the geysers and sometimes use a wire to clean them. Oh yeah, I just used 3 in 1 oil.
Post by Bikerrandy on Jun 26, 2008 20:20:05 GMT -5
I haven't oil mine yet, I've had it since November and everything still works great!
SteveHolmes
Member since July 2009
Post by SteveHolmes on Jun 30, 2008 5:53:07 GMT -5
Where exactly is it that you put the oil in for the pumps?? Steve
darrad
Post by darrad on Jun 30, 2008 6:41:25 GMT -5
Facing the unit take off the left cover. There will be 5 screws. The 2 on the lower left should be painted red. (At least mine are) Remove those, add a couple of drops and you're set. The sticker on mine says use 30wt oil but I went with 3 in 1
SteveHolmes
Post by SteveHolmes on Jun 30, 2008 23:10:06 GMT -5
Thanks stonewizard. It sure is nice to have such helpful and willing folks here on the RTH! Steve
Post by krazydiamond on Jul 1, 2008 8:02:32 GMT -5
my manual recommends oiling after 40 hours of use, i put a drop into each red screw hole every few months.
KD
