Post by rocklicker on Jul 7, 2008 18:33:42 GMT -5
Would it be OK to substitute the 600F grit stage with ungraded 400/800 grit for the "fine" stage? I've never used 400/800 grit before. My current recipe is: Rough 60/90 Medium 120/240 Fine 600F Prepolish Tripoli Polish Cerium oxide and sometimes alumina Thanks, Steve
Post by johnjsgems on Jul 7, 2008 19:10:57 GMT -5
You might have to run it longer to break down the 400 (coarser grit) in the mix. I learned from a book that called for 60/90, 220, 400, then 600. Most people now use the cheaper mixed grades 60/90, 120/220, 500F (also called 5F and is 500 and finer, with the next broad range being 800 and finer so I assume 5F is 500-just under 800). I commonly ran the 400 until it broke down then added the 600 if the slurry wasn't too thick without washing out.
darrad
Member since September 2006
Post by darrad on Jul 7, 2008 19:12:57 GMT -5
I have never heard of it let known try it but it sounds like a good idea to me. I use 500 for the "fine" stage and since I run mine in 2 week stages I think the 400/800 might be better prep work for the next stage. My line of thinking is the less work the next stage has to do to remove the scratches the better. I want my rocks to shine a bit before polish that way I know I will get a mirror shine. May I ask where you got the 400/800? I would like to try a batch with it. Dave
chassroc
Post by chassroc on Jul 8, 2008 11:58:42 GMT -5
Sounds like a plan!
Fine can be 400, 500 600 so 400/800 fits in nicely
csroc
