thomtap
Member since December 2007
Post by thomtap on Aug 11, 2008 9:24:50 GMT -5
I won a 12" lapidary saw blade, arbor, and pulleys on eBay. I want to make a slab saw with it. Here is a picture of what I won: Any suggestions? I have some ideas of my own, but I'd like to hear from others how you would do it. Thanks! Thom Tapp
thomtap
Post by thomtap on Aug 11, 2008 9:25:26 GMT -5
P.S. I have a good motor for this saw already.
Thom
Post by Jack, lapidaryrough on Aug 11, 2008 12:38:22 GMT -5
Slab Saw / Trim Saw ?
thomtap
Post by thomtap on Aug 11, 2008 13:42:30 GMT -5
I want to cut pieces up to about 3-4 inches. I have a trim saw, but thought I could build a saw now and then build a feed for it later. My trim saw only cuts pieces up to 1-3/4 thick.
Thom
Post by catmandewe on Aug 11, 2008 20:52:50 GMT -5
All you need now is a tank, a lid, a set of heavy guide bars, a table, and some kind of system to roll or slide on the guide bars and a clamp system. Weight feed is really easy to make, automatic feed is a little harder but very doable.
Good luck and show please show us your progress.
Tony
Simon
Post by Simon on Aug 12, 2008 1:02:05 GMT -5
I don't know if this would be of any use. It's a set of photos of a large slab saw in bits. May give you some ideas. Click the link tinyurl.com/6rbzrdSimon
thomtap
Post by thomtap on Aug 12, 2008 6:59:01 GMT -5
Thanks for the input. Simon, those pix help a lot!
Anyone have any pix of homemade slab saws?
Thom
Post by johnjsgems on Aug 12, 2008 9:01:20 GMT -5
You might want to search for a "drop saw". It would be much easier to build.
thomtap
Post by thomtap on Aug 12, 2008 10:16:31 GMT -5
Do you think this model would work for what I want to do: I think I could build something similar. (But not quite as fancy looking...) Thom
chadman
Member since March 2008
Post by chadman on Aug 12, 2008 12:04:26 GMT -5
All you need now is a tank, a lid, a set of heavy guide bars, a table, and some kind of system to roll or slide on the guide bars and a clamp system. Weight feed is really easy to make, automatic feed is a little harder but very doable. Good luck and show please show us your progress. Tony Actually sometimes the simplest ideas are best. Automatic feed: A cable and a pulley with a small bucket of water (one gallon milk jug) for a counterweight to put a constant pressure on the blade. add or remove a little water to adjust the feed rate. Add a spring for a snubber when the saw cuts through.
drjo
Honduran Opal & DIY Nut
Post by drjo on Aug 12, 2008 16:21:10 GMT -5
That's gravity feed Auto feed is connected to the drive system or has it's own motor. And your right, it is the simplest! Dr Joe .
Post by Jack, lapidaryrough on Aug 12, 2008 18:32:40 GMT -5
Actually sometimes the simplest ideas are best. Automatic feed: A cable and a pulley with a small bucket of water (one gallon milk jug) for a counterweight to put a constant pressure on the blade. add or remove a little water to adjust the feed rate. Add a spring for a snubber when the saw cuts through. Link to Post - Back to Top IP: Logged drjo New Member * member is online [send pm] Joined: May 2008 Posts: 24 Re: Building a Slab Saw « Reply #10 Today at 4:21pm »
Post by akansan on Aug 13, 2008 6:44:54 GMT -5
Here's the link that gets tossed around pretty frequently. I've looked hard at the saw detailed here, and I will eventually be turning an arbor I have laying around into a "good" trim saw based on this link. But I can definitely see how you could make a slab saw based on the same priciples... tomaszewski.net/Kreigh/Minerals/Homemade.shtml
drjo
Post by drjo on Aug 19, 2008 9:47:04 GMT -5
How the build going?
