Pendant
Oct 15, 2008 8:15:46 GMT -5
Post by connrock on Oct 15, 2008 8:15:46 GMT -5
A short time ago I bought some pink limb cast rough from stonesthatrock and it's GREAT material.Hard,solid and beautiful color. I modified Adrian's idea a bit by letting the sterling silver protrude around the stone a bit giving it a "frame". The cab was easy but I still have problems wrapping the bails! Grrrrrrrrrrrrrrrrrrrrrrrr!!! Comments and cretinisms are WELCOME! connrock
Pendant
Oct 15, 2008 9:38:09 GMT -5
Post by Noosh9057 on Oct 15, 2008 9:38:09 GMT -5
You did a great job. I love it.
Roger
drjo
Honduran Opal & DIY Nut
Pendant
Oct 15, 2008 9:44:41 GMT -5
Post by drjo on Oct 15, 2008 9:44:41 GMT -5
adrian65
Member since February 2007
Pendant
Oct 15, 2008 11:01:45 GMT -5
Post by adrian65 on Oct 15, 2008 11:01:45 GMT -5
Tom, I suppose if I'd say "Beautiful pendant" that would be considered a cretinism, not a comment? ;D But I wouldn't be far from truth saying that. The protruding style is very hard to do, as it requires a very constant depth of the groove. I've made it too, but using a twisted square wire because it looks better I think. Don't worry about the bails, I found them very hard to do in the beginning, always needed a third hand but now I'm quite content with the two ones that I own, LOL. Congratulations, and I almost forgot about the stone: this really IS gorgeous Adrian PS. A side pic would be great, as Dr Joe said above. To me it looks like the cab is double domed, and if it's so I wander how did you manage to use your grooving machine.
Pendant
Oct 15, 2008 13:55:04 GMT -5
Post by Tony W on Oct 15, 2008 13:55:04 GMT -5
Tom, you did good!! I have trouble with bails too, but yours looks fine to me. I just think we need to do 40 or so before we can get it like we want. So.... cretinous it is not! Tony
Pendant
Oct 15, 2008 17:08:38 GMT -5
Post by connrock on Oct 15, 2008 17:08:38 GMT -5
in a rush,,, back bottom originals,,,,http://imageevent.com/tcknkk/jewelry?n=0 connrock
Pendant
Oct 16, 2008 8:19:10 GMT -5
Post by Bejewelme on Oct 16, 2008 8:19:10 GMT -5
I think it looks great, I love pink anyway, so I love the stone, I like the simple wraps that really show off the stones, wrapping is hard, and it takes practice, I gave up, but can so much more appreciate other's work now having tried numerous times, and throwing the wire across the room.
Pendant
Oct 16, 2008 16:33:02 GMT -5
Post by connrock on Oct 16, 2008 16:33:02 GMT -5
bejewel, I found a way to stop me from throwing things in my shop.
I have a shallow pan of water under my bench filled about 3/4 full of salted water.
I keep 1 foot in the pan at all times.There's not enough room for both feet because the hair drier takes up a lot of room!
When I get the urge to start throwing things I just plug in the hair drier for a second or 2 and it really takes my mind of the throwing thing!
The draw back is that I can't do much for about 1/2 hour or until I stop shaking,,,which ever comes first!!
Adding the salt to the water really helped!!!
conn-nut
Pendant
Oct 16, 2008 19:39:56 GMT -5
Post by sitnwrap on Oct 16, 2008 19:39:56 GMT -5
The cab is so beautiful and displaying it on rough limb cast creates the perfect touch. The wrap is really nice I love the silver framing the stone.
Pendant
Oct 16, 2008 21:08:35 GMT -5
Post by frane on Oct 16, 2008 21:08:35 GMT -5
Hmmm, Beautiful cab, beautiful wrap and beautiful display. Wow! Fran
Pendant
Oct 17, 2008 4:40:50 GMT -5
Post by connrock on Oct 17, 2008 4:40:50 GMT -5
s'wrap, Thanks, I think I'm starting to get the hang of it now.
Fran, Thanks, I wasn't sure about pink and silver but I am sure about the cost of gold!! Maybe in my next life! LOL
connrock
Pendant
Oct 21, 2008 22:05:36 GMT -5
Post by Bejewelme on Oct 21, 2008 22:05:36 GMT -5
I'm getting the hairdryer and pans of water ready.
Pendant
Oct 22, 2008 8:53:21 GMT -5
Post by Tonyterner on Oct 22, 2008 8:53:21 GMT -5
Tom you just aint right. lol That is a very pretty wrap and I can see where that groove adds a lot of work, and grief, to the project. You did a bang up job on the wrap. That limb cast is such a pretty color, well worth the effort.
nancyf
Wired Cowgirl
Member since April 2007
Pendant
Oct 26, 2008 19:45:41 GMT -5
Post by nancyf on Oct 26, 2008 19:45:41 GMT -5
Super lovely stone! You say you have problems with bails? Get bail pliers from brandywinejewerysupply.com . You will use them for LOTS of others things too. Oh...I like more wire showing...way to go!
Pendant
Oct 27, 2008 13:20:18 GMT -5
Post by connrock on Oct 27, 2008 13:20:18 GMT -5
bejewel, Don't forget the salt or you'll just kinda shiver a bit!
Tony, Thanks, If you knew how much time and grief that notch saves me from wire wrapping you wouldn't think it was a lot of work. Making the "slab slitter" took a bit of time but to cut a cab with it takes less then a minute. Now if I can only make a stinkin bail!! LOL
nan'f, Thanks,,,,,
Thanks for the plier suggestion.They may save a life!! LOL
I agree that this piece could use just a "bit" more silver but it was kind of a trial thing. I DO NOT like a lot of wire but a little here and there looks great,,,,,to me!
connrock
nancyf
Wired Cowgirl
Pendant
Oct 29, 2008 9:30:31 GMT -5
Post by nancyf on Oct 29, 2008 9:30:31 GMT -5
oh...I meant on the edge. I liked the way you did it...not too deep into the stone, but deep enough to hold. Therefore, showing a little more wire. You'll love those pliers. To me, they are a MUST have.
