CUL-Ann
rock lover~
Member since September 2008
Post by CUL-Ann on Oct 31, 2008 5:08:12 GMT -5
If I use a golf tee to hold the cab while polishing do I use hot glue and heat it afterwords to remove it from the cab ?? and how do I polish the back side?? If I 1st glue one side then turn it over for the back side will the glue show bad on the 1st side??? thanks for any pointers;-)))
drjo
Honduran Opal & DIY Nut
Post by drjo on Oct 31, 2008 10:32:07 GMT -5
Always polish the backside first. The glue should come off completely and you may be able to part the two with a thin box knife and warm it up with just hot water, it depends on the glue stick.
Be careful how hot you get the stone (I do Opal and they don't like heat at all), as it may crack. The same goes when taking it off, make sure the stone isn't too cold when you put it in the hot water.
I use dop wax but have had great success with 'Plumber Goop' when the dop pot wasn't hot.
Dr Joe
Post by kap on Oct 31, 2008 11:58:38 GMT -5
I use golf tee's and 5 min epoxy it works great just run hot water over it and use a thin knife to remove. Keith
CUL-Ann
rock lover~
Post by CUL-Ann on Oct 31, 2008 20:27:05 GMT -5
I sent my hubby shoping and on the list was plumber goop and he tells me there is no such thing. would it be under another name??
Post by Bejewelme on Nov 3, 2008 21:02:42 GMT -5
I never thought about a golf tee, you guys are smart, Tony uses the epoxy and melts it off with a knife in hot water, sometimes the stones pop off on the 14,000 and 50,000, so I try to just do it for a few seconds at a time so the stone doesn't get too hot.
Post by Tonyterner on Nov 4, 2008 8:45:43 GMT -5
Personally I don't polish the backsides of my cabs. I like seeing the difference between the highly polished front and more natural back. Well its that or I'm just too lazy. The jury is still out on that one. ;D
Post by parfive on Nov 4, 2008 9:45:23 GMT -5
Tony - Any translucent or clear stone, a polished back will affect how the front looks. It'll let more light into or through the cab. (A little different than the facets on the back of a gem stone bouncing light around inside the stone, but close enough.) I lap and polish the back of all of 'em. Rich
drjo
Post by drjo on Nov 4, 2008 11:19:25 GMT -5
