Post by BuiltonRock on Dec 3, 2008 9:53:56 GMT -5
I need some help please !
I tried to make my first cab from Rhodochrosite. The stuff I have is soft and looked great through the 600 belt. When I put is on the resin belts with diamond paste some white patches developed.
I am thinking this rock is so porous the paste may have gotten into the face of the stone???
Anybody know?
Thanks in advance. john
RocknCritter
Member since November 2008
Post by RocknCritter on Dec 3, 2008 11:07:27 GMT -5
Do you have an ultrasonic cleaner?
I had some quartz that soaked up lot's of diamond paste. I thought everything was a goner. A friend recommended an ultrasonic bath and it cleaned up everything.
If you don't have one, I got my for $30 on eBay. It really is amazing sometimes to see all the crud in the bottom of the tank after cleaning stuff that looks absolutely pristine.
Post by Sabre52 on Dec 3, 2008 13:48:41 GMT -5
Howdy John, I've only cut a few rhodochrosite cabs and all were from the banded form of rough that works up very much like travertine. I did find the the size of the crystals in the bands varied from band to band and some of the bands were more porous. I polished, then cleaned out any white from the optical tin oxide I used with a water pick and the stones came out looking good. Some of the stones seemed to lack these porous areas and polished up real well with no problems at all so I guess maybe that was better quality stuff. My only real complaint about the material is if you use it in any jewelry that gets a lot of rubbing, it's softness makes the finish dull to a matte finish very quickly....Mel
Post by Michael John on Dec 3, 2008 14:47:05 GMT -5
Banded Rhodo is typically very pitted and porous. The finished pieces also break easily if they're thin and un-backed. Given these two "weaknesses", the best thing to do would be stabilization of the cleaned slab, before cutting or grinding.
Post by BuiltonRock on Dec 3, 2008 16:11:00 GMT -5
Thanks RC, Mel and MJ
I don't have a sonic cleaner, but I will see what I can come up with. May grind back at the 12K level and have a close look! Thanks again! john
