highplainsdrifter
Member since December 2008
Post by highplainsdrifter on Dec 31, 2008 11:16:36 GMT -5
I replaced my 280 grit Nova wheel on my Genie and really struggled to get the wheels re-balanced. It seemed no matter which way I rotated the wheels there was a slight "bounce," which really didn't change much as I rotated them.
Is there some trick or technique I'm missing? I guess it is just a mass distribution issue and I could sand the arbor a bit to balance, but I'm hesitant to do that.
Thanks, HPD
Post by bobby1 on Dec 31, 2008 12:43:55 GMT -5
Did you have the bounce before installing the new wheel? Maybe the new wheel is out of balance. Bob
Post by Jack, lapidaryrough on Dec 31, 2008 13:03:13 GMT -5
Is your unit the Lortone 6" cab unit, if so the rubber bearing rings around the bearing`s need`s to be compressed as it was, You should find marks as to how to alien the rubber ring.
As i have a Lortone 6" cab unit and it has a home on the floor. where it belongs with the other floor sweeping`s
As for the Nova wheel send it back, as i have never found a wheel of theirs out of balance's. As i don`t have a cue to your arber type and the machine your using.
Check the collier plates too.
highplainsdrifter
Post by highplainsdrifter on Dec 31, 2008 13:04:54 GMT -5
Did you have the bounce before installing the new wheel? Maybe the new wheel is out of balance. Bob There wasn't any noticeable bounce before I put the new wheel on. Since it was the plastic core Nova 280, I figured its light weight would have minimal impact on the entire arbor balancing. HPD
highplainsdrifter
Post by highplainsdrifter on Dec 31, 2008 13:12:16 GMT -5
Is your unit the Lortone 6" cab unit, if so the rubber bearing rings around the bearing`s need`s to be compressed as it was, You should find marks as to how to alien the rubber ring. As i have a Lortone 6" cab unit and it has a home on the floor. where it belongs with the other floor sweeping`s As for the Nova wheel send it back, as i have never found a wheel of theirs out of balance's. As i don`t have a cue to your arber type and the machine your using. Check the collier plates too. Forgot to mention it is a DP Genie. The new Nova wheel has minimal bounce, it is my Galaxy wheels that have it. Thanks, HPD
Post by Jack, lapidaryrough on Dec 31, 2008 14:01:44 GMT -5
Post by fishenman on Dec 31, 2008 18:11:31 GMT -5
Well, a couple of things come to mind. All surfaces mating surfaces of the wheels and spacers should be clean and free of any grit. I like to clean the edges of the Galaxy wheels whenever I have them apart.
Then, I try my best to fit the three wheels and spacers on the shaft as perfect to 90 degrees as possible. You know about turning the wheels. I have reversed direction and taken the wheels off the shaft 4-5 times to get just the right balance. Keep trying, you'll get it balanced again.
