docharber
Member since October 2008
Post by docharber on Feb 19, 2009 17:06:52 GMT -5
Oh all wise and knowing RTH sages, I beseach your guidance!
i am about to make some pendant drops and would like advice on the best/cheapest way to drill holes in the stones, including machines, recommended bits, etc. I have a dremel and some diamond burrs but they are either too coarse or fragile and I want to do a really smooth job and not have to repolish the surface afterward. :help: :help: :help:
Mark H.
Post by Bejewelme on Feb 20, 2009 13:44:21 GMT -5
My advice is to not drill!! Can you use wire and epoxy instead? I hate drilling into stones, and especially cabs, all that work to then see them break! So sad!
Post by Hard Rock Cafe on Feb 20, 2009 13:59:22 GMT -5
I've used a Dremel with diamond bits in the past. The key is to go slowly and keep the stone under water. You want to use a pulsing action with the bit.
When this has come up before, others suggested drilling before polishing.
Hope that helps, Chuck
Post by akansan on Feb 20, 2009 14:06:52 GMT -5
Zotika has an excellent tutorial on how he drilled his pendants. Let me see if I can dig it up in the Lapidary Tips.
Post by akansan on Feb 20, 2009 14:15:55 GMT -5
misguidedone
Member since May 2007
Post by misguidedone on Feb 21, 2009 11:58:40 GMT -5
misguidedone
Post by misguidedone on Feb 21, 2009 12:37:47 GMT -5
rockbottom
Member since August 2008
Post by rockbottom on Feb 21, 2009 18:18:34 GMT -5
Steve, how many holes can you get out of the 2mm size, and are they the same price?
I've been buying 100 - 1mm drills from China for $25.00 and reaming the hole out with a 2mm drill. I only get about 2 holes to a bit, so core bits ought to save some money.
Bob
misguidedone
Post by misguidedone on Feb 21, 2009 19:50:09 GMT -5
Bob, Their super small diamond core bits are $4.75 and are 1.5 - 3mm. Twenty holes with these bits on the average. Here is a link: www.dadsrockshop.com/diamond_drills.htmlI got a bit off topic as I drill my holes prior to the vibe. Very important to make sure the slug is clear from the core. Don't ever pick at the end of the bit or shove a close fitting nail into it to extract the slug. I use a thin, stiff, stainless steel wire and carefully push it out. I also would not use a core bit in a hand held device. Steve
docharber
Post by docharber on Feb 21, 2009 21:21:17 GMT -5
Guys, thanks very much. I want to cut earring and pendant stones for a friend of my sister-in-law who makes jewellry. SShe does wire wraps and pendants liek steves. I an accumulating boxes of slabs and need to do something with them.
I checked out my new Lortone catalog and they have core bits, too- for over $30 each. Thanks for the lead. i need to save where I can.
Mark H.
docharber
Post by docharber on Feb 22, 2009 14:25:46 GMT -5
I.'ve been PMing Steve and he told me to run the core bits at 1500-2000 RPM. I was mistaken about the prices on the bits in the Prtone catalog. Dad's is a little cheaper but freight is higher. $13 by Fed Ex ground- no options offered at checkout- for for eight little bits and dome gem templates. Their grit prices were high too. They had some super deals on cabbing units, though.
mark H.
rockbottom
Post by rockbottom on Feb 24, 2009 12:57:59 GMT -5
Thanks Steve for all the information. I think I'll order a couple each of 4mm and 2mm. Sounds like best way to go.
Bob
