brent
Member since November 2008
Post by brent on Mar 1, 2009 20:03:23 GMT -5
I finally got around to building a flat lap. It still needs some minor work, but it works as is. Total cost without the lap discs is under $10
88pathoffroad
Oregon ROCKS!
Member since August 2008
Post by 88pathoffroad on Mar 1, 2009 21:00:45 GMT -5
Details? Don't leave us hanging!
brent
Post by brent on Mar 1, 2009 21:30:12 GMT -5
It has a small motor that was laying around. It is 10" across and 8" high, built with scrap 5/8" plywood. It has the bottom of a plastic bucket for a splash guard. It is a direct drive unit. I need to secure the splashguard yet, so I can use it vertically as well as horizontal. I also need to supply airflow to avaiod overheating of the motor.
NDK
Post by NDK on Mar 1, 2009 21:37:19 GMT -5
Nice work Brent. Man, you guys make this look easy. Thanks for sharing.
Nate
drjo
Honduran Opal & DIY Nut
Post by drjo on Mar 2, 2009 7:59:02 GMT -5
Nice work, How did you seal the motor shaft?
Dr Joe
Saskrock
Member since October 2007
Post by Saskrock on Mar 2, 2009 9:32:46 GMT -5
Great job. Looks like it would be easy to put a computer cooling fan on Brent. They almost always have those at princess auto for a couple of bucks.
Mudshark
Diplomacy is the art of saying 'Nice doggie' until you can find a rock. Will Rogers
Member since December 2008
Post by Mudshark on Mar 2, 2009 10:09:32 GMT -5
Nice job Brent.On the one I just made the arbor sticks up thru a pvc plumbing fitting,it is threaded on the bottom and I used an electrical locknut to secure it,then seal it and the drain fitting with silicone.The water flies off the wheel and drips down thru the drain hole and back into the water tank to be recirculated.There is no seal on the arbor shaft but so far after a couple hours of use there is no water at all going down the shaft hole.Mounting a fan on yours should be real easy,a "muffin" fan used in computers would be a cheap way out. Mike
grant
Member since March 2007
Post by grant on Mar 2, 2009 10:22:07 GMT -5
Put a "slinger" of some type on the shaft itself and I doubt if you would ever need a seal unless you decided to do underwater cabbing
brent
Post by brent on Mar 3, 2009 8:06:22 GMT -5
All I did for a seal was build up some silicone around the hole in the slash pan.
Post by phil on Apr 13, 2010 18:38:29 GMT -5
what RPM's should a unit like this be running at?
Thanks!
Post by Hard Rock Cafe on Apr 13, 2010 21:18:41 GMT -5
Nice build! I agree on the slinger.
drjo
Post by drjo on Apr 13, 2010 21:44:40 GMT -5
what RPM's should a unit like this be running at? Thanks! 800-1800 RPM's is good. Dr Joe .
