Thunder69
Thunder 2000-2015
Post by Thunder69 on Mar 12, 2009 20:41:12 GMT -5
I see alot of posts about gas buid-up in barrels and was wondering if anyone has tried things like gas-ex or beano to reduce the gas buid-up ..John
MikeS
Post by MikeS on Mar 13, 2009 17:00:38 GMT -5
one thing I've done in the past that helps a bit is to use very hot water when setting up the tumbler. Asthe water cools, the tumbler is already sealed, so it lowers the pressure inside the tumbler, and the gas doesn't seem to build up as much pressure later...
Post by Woodyrock on Mar 13, 2009 19:02:02 GMT -5
I do a pre grit run with borax, and that seems to help, or I just may not have gassy rocks. I have an old Lapidary Journal (May 1965 pp244) with an article about a big (like three feet diameter by four feet long) exploding from the gas igniting thus blowing the tumbler apart. The rock being tumbled was all pet wood. The explosion was thought to have been caused by the pressure like the ignition of a diesel engine. What ever caused the explosion, it did blow the tumbler apart. This was a commercial company, and they installed pressure reliefs in all of their tumblers after this accident. Woody
Post by johnjsgems on Mar 13, 2009 19:06:13 GMT -5
You shouldn't have much trouble. The old books always said to "burp" the drums every 3 days or so. I've only had one lid blow off ever. If you see a drum or lid bulge open it up. I think the old guides said to add a little baking soda but I've heard Tums too. I mostly hear it is a problem with glass and unwashed rock with organic debris. I generally use 1/3 less grit than called for and check every three days. If it looks like I need more grit I add a little more. That takes care of burping also.
Post by cpdad on Mar 14, 2009 17:43:21 GMT -5
just pay attention to the bottom of your barrel....if it stays flat or protrudes outward a little....burp it.... the bottom of my barrels actually suck towards the lid slightly if all is good.
if you notice any outward movement of the bottom of the barrel....burp immediatly...or get a big surprise ;D.
cleaning the rocks before tumbling helps a ton.....hot water does help a little....as long as the gas build up doesnt over ride the gains of the hot water pressure difference.
as for as your question goes ;D....i have never used anything at all....all i have done is watch the bottom of the barrel...kev.
Post by johnjsgems on Mar 14, 2009 22:04:58 GMT -5
I think the hot water trick is more of a remedy to get a better seal rather than prevent gas buildup. Kev has pretty much nailed it.
