Post by mohs on Mar 28, 2009 21:30:58 GMT -5
I have this piece of tombstone granite its the neighbors actually and she would like the flat polished Its about 7" long & 1" inch wide and fairly smooth now I have flat lap but only a 220 grit lap I think that too rough so I'm thinking elbow grease & honing stone anyone ever polish granite? ideas?
Post by johnjsgems on Mar 28, 2009 23:59:45 GMT -5
If it needs to be flattened the 220 grit will work fine. If you have a tile place around there are diamond hand pads in various grits for countertop touch up, etc. You could also check automotive paint suppliers for wet/dry sand paper. Countertops are finished with diamond pads in 50, 200, 500, 1000, 2000, and 3000. They sometimes use a white or black polish pad but I don't think it contains a polish. I think it is a finer grit like 8000 or something. Granite usually contains quartz and feldspar and shouldn't be a problem to polish.
Post by mohs on Mar 29, 2009 13:30:54 GMT -5
thanks john excellent info Its better looking than the photo shows but it could be much better it as some pitting in it i'm cautious of going after I did the honing stone trick & that worked well then I put it on the expandable drum with a cerium oxide belt got a nice gleen to it
