jcinpc
Member since April 2009
Post by jcinpc on Apr 10, 2009 22:43:03 GMT -5
Post by fishenman on Apr 11, 2009 16:39:41 GMT -5
Beautiful cab. Is that heat-treated material or natural colors? I don't use CO but a toothbrush might do the trick. A ultrasonic cleaner would work the best though.
jcinpc
Post by jcinpc on Apr 11, 2009 17:12:48 GMT -5
thanks, its raw, if I cooked it the clear would turn white and I didnt want that on this piece. I really dont care for the CO so maybe I`ll use something else, toothbrush didnt do it yet.
Post by sitnwrap on Apr 11, 2009 20:44:41 GMT -5
That is a really pretty cab and I love that black stripe with the orange.
Post by Tony W on Apr 12, 2009 11:17:02 GMT -5
Really nice! Yeah, I think you'd best invest in an ultrasonic to get into pits and pores. T
jcinpc
Post by jcinpc on Apr 12, 2009 11:26:36 GMT -5
what is an ultrasonic?
Post by fishenman on Apr 12, 2009 11:45:13 GMT -5
Jeff, They are cleaners that use sonic vibrations to clean. Here's a website- www.cleanosonic.com/Geoff
Post by Bejewelme on Apr 12, 2009 18:02:07 GMT -5
I got a pressure cleaner from a drycleaner, I will find the link that Mossyrockhound recommended, that little thing blasts everything out! I will look for it, I think it is on Litho Valley Supply, like a pressure washer for cabs!!
Post by frane on Apr 12, 2009 21:12:32 GMT -5
Now that really was a great pictorial all the way through! You ended up with a very pretty cab! Fran
Post by fishenman on Apr 12, 2009 21:35:05 GMT -5
This gun Amber? roederindustries.com/shopexd.asp?id=5I have one and they are very powerful. In fact you can puncture the skin with the stream of water and blow off loose crystals and druze. I use it to clean allot of stuff, I love it. Geoff
Post by 150FromFundy on Apr 13, 2009 6:05:24 GMT -5
I like the way you showed your work from slab, to pre-form, to finished cab. It's great for us newbies that dream of cabbing one day.
If you don't have an ultrasonic cleaner, visit your dentist. I'm sure they will clean it for you along with some dentures and partial plates. LOL
Your local jeweler should also offer you this service. Probably for free if you are a customer there.
150FromFundy
jcinpc
Post by jcinpc on Apr 13, 2009 10:53:56 GMT -5
found the cleaners at walmart for $40. 2 so far are soldout, need to check a third.
Post by Titania on Apr 13, 2009 14:05:08 GMT -5
Fantastic cab! I love the color in this material!
highplainsdrifter
Member since December 2008
Post by highplainsdrifter on Apr 14, 2009 9:00:46 GMT -5
Very nice material and a fine cab. I use an ultrasonic, but still have to use the toothbrush for the stubborn pits. The high pressure gun sounds like a pretty good option for getting stuff out of pits. I haven't tried one of those yet.
Post by Bejewelme on Apr 14, 2009 11:16:54 GMT -5
Geoff that is the same gun, I LOVE that thing!!!! I am cleaning everything with it. I swear I hit my finger with it, and it hurt for 2 days, that thing is powerful! Now I lay a towel in the sink and then blast them, I gave up trying to hold and blast, the thing is sort of heavy to hold in one hand. That was the best $60 I spent, I cleaned my tile saw, it cleans everything!
mossyrockhound
Member since January 2011
Post by mossyrockhound on Apr 14, 2009 14:01:39 GMT -5
jcinpc
Post by jcinpc on Apr 14, 2009 14:44:38 GMT -5
thanks Garry, I will ask though would I just use water or do I need a solvent or someting else?
jcinpc
Post by jcinpc on Apr 14, 2009 14:49:10 GMT -5
mossyrockhound
Post by mossyrockhound on Apr 14, 2009 17:18:56 GMT -5
Jeff, For the spot-cleaning gun, you just use water and add a drop or two of dishwashing detergent for lubrication every time you fill up the plastic container. Very simple and effective. Just be sure to wear a heavy rubber glove on the hand that you are using to hold the piece being cleaned, because it puts out about 1650 psi pressure. BTW, that latest cab is a dandy! Garry
