buck570
Member since February 2009
Post by buck570 on Sept 14, 2009 21:36:01 GMT -5
any one looking for a big saw needs to look at st. louis craigs list. Willis Smith of the old Smiths rock hut is looking to thin out his stock. It's a home built saw, using covington parts, stainless steel box , recycling oil thu a settling box ,hydraulic drive. The bad part, the hydraulics are homebuilt using a refrigerator compressor, presser sensor,and old r22 tank as a reservoir,hasn't been used in years,rotted seals and diaphragms. Will have to be rebuilt. And cleaned. The good news. the bearing are good ,vice tracks true ,piston is good, box is sealed. The saw come with a good blade,and a brand new blade. The guts alone run about 3gs new, the blades run close to 500. Listed at 1200 The hydraulics may work,they did when it was stored. Must be picked up .
