carloscinco
Member since July 2008
Post by carloscinco on Sept 16, 2009 18:57:50 GMT -5
I started with a piece of Succor Creek Jasper about 10"x5-7"x5". Too large for my WF saw to slab. I cut a groove on three sides to isolate a piece about 3" thick. I split it off the main rock with a hammer and chisel. I got lucky and it broke off in one piece. I tried for a 1" thick split but it broke in two pieces. The next split was about 2 inches and it broke off as one piece. I have 4 smaller pieces total and 1 larger piece. Now I'll try to slab and make tumbling rough with the four smaller pieces and save the big one for later. I can see Oregon from here!
Post by Toad on Sept 16, 2009 19:03:53 GMT -5
How did you make the cut in the large rock?
Post by frane on Sept 16, 2009 19:14:01 GMT -5
Beautiful colors in that rock! that piece should give you some very nice small slabs! Fran
carloscinco
Post by carloscinco on Sept 16, 2009 19:14:54 GMT -5
I used the work force saw and kind of 'eyeballed' it as I rolled it to cut three of the four sides. The fourth side had too much angle to be able to saw it. The inner part that I could not reach with the blade was about 2"x3" on the first piece and about 3"x4" on the next two attempts.
Post by Bikerrandy on Sept 16, 2009 19:17:24 GMT -5
Nice material, looks like breaking it down went smoothly.
Post by Sabre52 on Sept 16, 2009 19:39:54 GMT -5
Wow! Great work! Looks to be an exceptional piece of Succor Creek too. That blue is real nice!....Mel
karock
Member since November 2007
Post by karock on Sept 16, 2009 21:52:31 GMT -5
You are so brave. This is the biggest rock I have ever seen cut by a WF. Risk had its rewards here, very nice colors. Thanks for posting Karock
Post by johnjsgems on Sept 16, 2009 22:00:14 GMT -5
You did a great job. I've tried the throwing it on the floor method. I still find pieces when I sweep.
Post by sitnwrap on Sept 16, 2009 22:31:32 GMT -5
Those are really pretty and the cuts look great. Thanks for the chissel and hammer idea.
SteveHolmes
Member since July 2009
Post by SteveHolmes on Sept 17, 2009 6:50:23 GMT -5
I'm very impressed that you were able to do that on a WF! Wow! That's a Beautiful Rock too with some great scenes. Steve
Post by Toad on Sept 17, 2009 7:01:17 GMT -5
So a WF really can do anything!
Post by Tonyterner on Sept 17, 2009 13:31:31 GMT -5
Pretty slick. I'll have to give that a try. Thanks.
