Roger
Post by Roger on Sept 21, 2009 8:59:08 GMT -5
Some of these need a little work.I will try to tag each one.I leave for Portland for a week of R&R wine and other stuff. black hills agate/wyo jade mex lace/obsidian work in progress hills agate/jasper/wyo jade hills agate/obsidian backlite hills agate/jasper/biggs jasper hills agate/biggs jasper mex lace/obsidian mex lace I hope the tags worked........Thanks Roger
Post by Bikerrandy on Sept 21, 2009 11:42:09 GMT -5
Beautiful stones, awesome work!!
Post by sitnwrap on Sept 21, 2009 12:52:50 GMT -5
I love looking at your intarsia work. I also love it when I can't decide which one is my favorite. I would normally chose the one with what looks like a drusy center but there is too much eye candy here.
Have a great trip.
Post by Tonyterner on Sept 21, 2009 14:24:21 GMT -5
Nice looking cabs Roger. I noticed on the see-thru one that the rock tends to break a lot as the hole saw goes through the back. Try backing it up with wood or another rock to eliminate that.
Roger
Post by Roger on Sept 21, 2009 14:40:06 GMT -5
Thanks,Tony good idea, so far I use a hand drill. I press a little to hard.Plus you have clamp or hold on tight when it breaks thru the slab spins, could slice a finger real easy.i need to build a drill press...Thanks Roger
Post by Bejewelme on Sept 21, 2009 19:41:28 GMT -5
Roger! Those look awesome!! Have fun drinking wine and relaxing!!!! Maybe you will have new inspiration to blow us away with when you return!!!! Amber
aunuts
Some days are gold, some are rocks. Either is cool.
Member since March 2006
Post by aunuts on Sept 22, 2009 0:41:55 GMT -5
Hi Roger, Those are mind-blowing! Have you posted any instructions on these? Do you set them into the base? Or just glue them on top & cab them from that point? I've got an order for a cross & would love to be able to set it into/on obsidian. Can you give me some pointers?
Thanks a lot for sharing your beautiful, beautiful work with us.
Jo
Roger
Post by Roger on Sept 22, 2009 10:14:26 GMT -5
Hi Jo,I have not posted instructions yet I started then got side tracked making more cabs.I use a core drill found on jadecarver.com then I hand grind the center to fit, then I opticon the 3 pieces together the dounut the hole and the base.let dry,cut and grind.I would make a cross then add pieces to make it round then fit it in a hole from the core drill.I will make one next week Great idea!!.....Roger
karock
Member since November 2007
Post by karock on Sept 22, 2009 22:10:07 GMT -5
Great pieces, especially the last two. Thanks for posting Karock
