Post by Woodyrock on Feb 3, 2010 1:56:44 GMT -5
Here is what the diamond polisher looks like so far. The ten inch drums are laminated MDF, with a half inch layer of neoprene foam backing. There will be eight ounce leather over the foam with 14,000 grit on one, and 50,000 grit on the other. Woody The basic drum The drum painted, and backing applied
drjo
Honduran Opal & DIY Nut
Post by drjo on Feb 3, 2010 9:36:00 GMT -5
How big are the diamonds you have to polish?!? Man, you'd have to have a BIG woodworking shop to build something like that! ..... Oh wait... It looks like you DO! Nice work, are you going to overlap (angle cut) the leather 'belt' edges? When do they go on sale? Dr Joe .
Post by Woodyrock on Feb 3, 2010 18:42:16 GMT -5
Dr. Joe: The shop is large enought to build up the 25' boats. I did do one at 31' but that was a real pain...the shop is only 32' inside.
I am toying with the idea of making leather belts for three inch expando drums. I first want to see if my joining method holds together. The belts will be scarphed, and glued. Woody
blessed
Member since January 2010
Post by blessed on Feb 3, 2010 20:35:41 GMT -5
Woody Nice job looks great, should do some good work. I see you are just like the rest of us woodworking people. Never throw a piece of scrap away, might need it sometime.
Blessed
PS. You might want to feather the edges on the leather where it overlaps. One directional, but it won"t snag and come apart.
NDK
Post by NDK on Feb 3, 2010 22:55:07 GMT -5
Awesome polisher so far Woody. Man, you've been busy!
Nate
Post by sandsman1 on Feb 4, 2010 0:56:14 GMT -5
thats gonna be nice man and i like how wide the belts will be makes it easy when you have a large cab --- lookin good cant wait to see it done
drjo
Post by drjo on Apr 25, 2010 6:53:42 GMT -5
How'd the wheels work?
And the leather belts?
You didn't let work get in the way of this. did you?!
Dr Joe
Post by Tommy on Sept 2, 2022 10:25:29 GMT -5
Because this thread is featured on the new and improved DIY Lapidary Equipment page I am working on, I Updated this thread to provide a better more complete conclusion to the project write-up. Woodyrock created two separate update threads and I have quoted them here including a lot of really amazing pertinent to the OP - Tommy Quoted from: forum.rocktumblinghobby.com/thread/49590/drum-framesSeeing as how the weather was wet, and cold today here in the great Pacific Northwest I decided to light off the steam box, build a fire, and bend some drum frames of of some air dried White Oak. You will readily see this is no high tech operation but it does work. The steam box itself is a length of fibreglas pipe, the source of steam an old pressure cooker sitting on top of the crab cooker. The drum frame former is just a 16" wood disc bolted to a saw horse so it can rotate. Here is the steam box This is the frame former This is an hours worth of bending setting up. Quoted from: forum.rocktumblinghobby.com/thread/50240/drumsWell, you saw the drum frames I made a while back, so here are drums. My, her brother, and I got together, and took a class at a nearby reservation on drum making Saturday, then today, we made more drums at home. During the class, a Skokomish weaver show us how to weave the handles which looks a lot better than just plain wrapping them. Five of the drums are elk skin, one of which was neck material which is thick, so that drum has a very deep voice. The sixth drum is deer hide, which is much thinner than elf, so it has a much higher pitched voice. Punching the lacing holes Lacing the skin edge Getting the skin on Lacing the drum Weaving the handle Finished handle Finished drums..one is was being played when I shot this
