Post by bobby1 on Feb 11, 2010 22:37:44 GMT -5
This one is 7mm (about 1/4") across and I made it from Idocrase for a jewelry piece that I'm working on. I wanted to have a perfect hemisphere shape so I took it to my "sphere" making machine. This machine is a motor mounted vertically with a Jacobs chuck mounted on the shaft. I make my sphere making cups from steel shaft material of various sizes with a cup drilled into the working end. When you make a sphere (or in this case hemisphere) shape you want the cup diameter to be about 2/3 of the size of the sphere. I ground the cab to as close to a hemisphere as I could get on my lapidary grinding wheel. Then I went to this sphere machine and started the grinding using 120/220 grit tumbling media. I mix it with water in a small container and dip the cab in to coat it with grit and rotate the cab on the grinding cup. When it has reached the perfect sphere shape I then go to 400 grit and finish with 600 grit. I polish the cab on my regular carpet covered wheel with Cerium Oxide. Bob
Post by fishenman on Feb 11, 2010 23:21:43 GMT -5
That is really awesome Bob. What a great idea.
bobh
Member since September 2009
Post by bobh on Feb 11, 2010 23:32:58 GMT -5
Now that is really creative. Nicely done. Bob
WyckedWyre
Member since April 2007
Post by WyckedWyre on Feb 11, 2010 23:46:03 GMT -5
I want one of those!
:oS
adrian65
Member since February 2007
Post by adrian65 on Feb 11, 2010 23:53:34 GMT -5
Sir, when you say "big" it's BIG, and when you say "small" it's small ;D
Such a perfect shape and dome on this tiny cab! Thank you for the idea.
Adrian
Post by Bejewelme on Feb 12, 2010 14:39:27 GMT -5
Bobby: Don't ever admit its not big WOW that is tiny, but shaped perfectly!!!!!!!!
Post by Toad on Feb 12, 2010 14:46:28 GMT -5
Beautiful cab and clever machine.
Post by krazydiamond on Feb 12, 2010 19:18:38 GMT -5
small and perfection.
KD
NDK
Post by NDK on Feb 12, 2010 21:34:29 GMT -5
Very cool teeny cab Bob!
What speed do you run the sphere machine at?
Nate
Post by bobby1 on Feb 12, 2010 22:01:43 GMT -5
Nate, It runs at the speed of the motor which is 1725 rpm. If I were to build another I would look for something where I could control the speed. This one runs too fast and tends to sling the grit out rather than retain it for more efficient grinding. Bob
fossilbrain
Cookie Monster agate
Member since October 2007
Post by fossilbrain on Feb 13, 2010 7:29:35 GMT -5
My grandfather left me a couple this size and I haven't tried anything quite that small yet, so, nice to see how you dopped it
Post by bobby1 on Feb 13, 2010 12:49:11 GMT -5
When I made the grinding cups I made them with a 1/4-20 threaded shaft so they will fit on the Hi-Tek All in One, Ameritool and the right hand side of the Genie. With the first two machines they have a speed control so they can be slowed down enough so that the grit doesn't sling out very much. Bob
damammy
Post by damammy on Feb 13, 2010 15:41:04 GMT -5
Wow man when you have a stone that small and do it perfectly you are a master not to mention patient. Donna
Post by frane on Feb 13, 2010 20:27:34 GMT -5
That is just too cool! You really do amazing work and that one just looks perfect! Fran
southforkmining
Member since October 2006
Post by southforkmining on Feb 13, 2010 21:26:34 GMT -5
Bob..is that idocrase from pulga deposit
Post by bobby1 on Feb 13, 2010 23:03:06 GMT -5
Rich, There is a small dark green spot on one side that didn't show in the photos so most likely it is a piece from Pulga. Bob
