riverrock
Member since April 2010
Post by riverrock on Apr 29, 2010 20:13:01 GMT -5
I bought a WF saw and cut a few goedes so start with. But when i cut i get soaked with the water spray. Do i have to wear a rain coat ?
Post by FrogAndBearCreations on Apr 29, 2010 20:24:32 GMT -5
I made a plexi sheild that I put on the front of the saw and the spray for the most part hits that and not me. I made it just tall enough to look over and the full width of the front of the saw tray so the only part that get wet now are my arms from the elbows down
Post by 150FromFundy on Apr 29, 2010 21:14:36 GMT -5
Stand behind the saw and pull the rocks towards you rather than push them from the front. Very little water sprays from the back of the saw. It is all directed towards the front.
This takes a little getting use to at first, but once you do, you will never stand in front of a wet tile saw again. You may also live a little longer. That spray isn't all that good for you.
Darryl.
Post by beefjello on Apr 29, 2010 22:02:22 GMT -5
But getting soaked is half the fun! OK, maybe half of half the fun.. and then only in summertime lol. I think Darryl's got the right advice there, stand (or sit) behind it.
Post by Tonyterner on Apr 30, 2010 8:56:00 GMT -5
I tried standing behind the saw but didn't like it. I like to see the contact point between the rock and blade to keep the cut straight as possible. I just wear a face mask and an apron. In the summer it is nice to get wet so I just go with the face mask.
Wolfden
Member since November 2007
Post by Wolfden on Apr 30, 2010 22:14:12 GMT -5
Rain gear lol or else stand behind and pull the rock towards yourself
NDK
Post by NDK on Apr 30, 2010 22:19:10 GMT -5
I have the same as 2badfrog. I clamp on a lexan shield I made for it. If it's cold out I also wear a raincoat to keep m arms dry. If it's really cold out, I have neoprene gloves I wear too.
Nate
Post by Bikerrandy on May 1, 2010 7:05:08 GMT -5
I stand behind the saw. Problem with standing in front of the saw is that you have to clean your face shield quite frequently. I can cut for hours and stay dry the entire time, and see what I'm cutting the entire time.
