Post by sandsman1 on May 22, 2010 2:57:09 GMT -5
dam tony that saw looks new hellofa job man
adrian65
Member since February 2007
Post by adrian65 on May 29, 2010 11:48:06 GMT -5
What a great transformation! You did a wonderful job.
Is that reductor (painted in red in the 3rd pic) a coil/wheel one? Do you have any idea what reduction ratio does it have?
Adrian
Post by catmandewe on May 30, 2010 10:34:58 GMT -5
Thanks everyone
Adrian, that shaft has a worm gear on the end of it, which in turn drives a sprocket which turns the threaded feed screw. The worm gear is about 1/2" and the sprocket is about 4 or 5", there is also a 3 step pulley under that cover to change the speed of the worm gear. Hope that helps you find what you are looking for.
Have a great day...............Tony
adrian65
Post by adrian65 on May 30, 2010 15:24:59 GMT -5
Thank you Tony, yes it's exactly how I supposed. Thanks for the dimensions also.
Adrian
