Post by jakesrocks on Sept 6, 2010 21:14:54 GMT -5
A tip for thickening the slurry in your tumbler barrels. I keep several gallon ice cream buckets, and pour the mud from my tumblers into them. One clearly marked bucket for each grit stage. I cover the buckets with several layers of cheese cloth to keep bugs and dirt out. The water slowly evaporates, leaving hard mud and grit behind. When I start a fresh tumbler batch, I break off a piece of the hard mud about half cup size and add it to the barrel. This gives the slurry a kick start, and helps hold the grit to the rocks. It cuts several days off of the first couple of stages. Don
turnedstone
Member since January 2006
Post by turnedstone on Sept 7, 2010 21:41:17 GMT -5
Been doing the same thing since someone on here said it 4 years ago when I first joined RTH, just made sense to my frugal mind that some saving could be had from following this. George
