rockhappy
Member since September 2010
Post by rockhappy on Sept 25, 2010 21:36:03 GMT -5
Hi All-
Finally got my first (ever) load tumbling. I've got a QT66 with both barrels running.
I've noticed that the motor is quite hot. Is this something I need to be concerned with and if so, any suggestions on how to cool it?
Thanks.
--Hol
Post by susand24224 on Sept 26, 2010 3:36:18 GMT -5
I don't have a QT66, but I have three Lortones All three run hot to the touch, even approaching *ouch* temperature.
Susan
papat
Member since July 2010
Post by papat on Sept 26, 2010 5:27:56 GMT -5
i have a qt 66 it runs hot to the touch its been running about 3 months steady and dount seem to hurt it
Tim
revco
Post by revco on Sept 26, 2010 10:20:00 GMT -5
This perfectly normal, so you're not experiencing a design flaw or anything. These motors run extremely hot. I've run one for nearly two years straight with no trouble.
Personally, I know that high heat reduces a motor's life - so I put a cheap fan on mine to try and dissipate heat, hoping that it will extend its life by a few years. It still runs extremely hot, but if it bothers you a lot, this gives a little piece of mind.
I don't want criticize Lortone, because they do make good tumblers, but to me - this is a sign of a cheap motor. No doubt, like many other things these days, they've had to reduce costs to maintain a reasonably priced product.
rockhappy
Post by rockhappy on Oct 4, 2010 21:06:29 GMT -5
Just an update. Revco, I took your idea of a putting a small fan on the motor and it is making a big difference in the temp. Still feels warm but much better than before -- to the point of being able to hold the motor whereas before, it was far too hot for that.
Thanks.
--Hol
jasperblue
Diggin' This
Member since August 2010
Post by jasperblue on Oct 11, 2010 23:33:47 GMT -5
Yes, Lortones run hot. As everyone can attest, this is normal. Just make sure the motor is getting good ventilation and they will run for years. -Chris.
rhof59
Member since July 2021
Post by rhof59 on Jul 24, 2021 20:16:29 GMT -5
My Lortone 3A runs hot, but in the past couple of weeks has kinda siezed up and stopped. The motor is still going but the "Drive Shaft" freezes. I've oiled it and got it working but I feel like I need to keep an eye on it. Any comments?
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Jul 25, 2021 6:48:13 GMT -5
My Lortone 3A runs hot, but in the past couple of weeks has kinda siezed up and stopped. The motor is still going but the "Drive Shaft" freezes. I've oiled it and got it working but I feel like I need to keep an eye on it. Any comments? Lortone recommends 1 drop of oil on each roller Bearing every month
Post by aDave on Jul 25, 2021 23:25:03 GMT -5
Hi All- Finally got my first (ever) load tumbling. I've got a QT66 with both barrels running. I've noticed that the motor is quite hot. Is this something I need to be concerned with and if so, any suggestions on how to cool it? Thanks. --Hol Run the tumbler without the cover over the motor space. If you're not in a dirty environment, this shouldn't cause an issue at all. All of my Lortones have been run without the covers...for years.
Post by Fossilman on Jul 28, 2021 16:19:53 GMT -5
Hi All- Finally got my first (ever) load tumbling. I've got a QT66 with both barrels running. I've noticed that the motor is quite hot. Is this something I need to be concerned with and if so, any suggestions on how to cool it? Thanks. --Hol Run the tumbler without the cover over the motor space. If you're not in a dirty environment, this shouldn't cause an issue at all. All of my Lortones have been run without the covers...for years. As I also do .... It does help..
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on Jul 29, 2021 0:15:40 GMT -5
Run the tumbler without the cover over the motor space. If you're not in a dirty environment, this shouldn't cause an issue at all. All of my Lortones have been run without the covers...for years. As I also do .... It does help.. Leaving the cover off of the tumbler would only apply to the 3A and 3B tumblers The motor on the QT66 is already outside the unit
Post by aDave on Jul 29, 2021 8:47:57 GMT -5
You're right. I missed that's what is being run by the OP. I only saw the Lortone name and went from there. Add the 45C to your list, as that's what I ran in addition to my QT66.
Post by greig on Jul 29, 2021 10:20:56 GMT -5
So when my wife complains the bedroom is too cold in the winter, can I move my tumblers there?
I like all of the answers and will add another thought. The people who build a sound insulated box for their tumbler are increasing the heat problem and asking for trouble.
HuntingHuron
Member since October 2020
Post by HuntingHuron on Aug 2, 2021 14:57:17 GMT -5
I've mentioned this on one other thread. I raise my Lortones onto 1/2" standoffs for improved convection cooling.
