Post by Hard Rock Cafe on Nov 1, 2010 12:38:34 GMT -5
Just posting a recently learned lesson about buying a used Rock Rascal Model J: you're probably better off buying a new saw if the bearings need to be replaced. The Model J uses custom bearings that cannot be found elsewhere (I check McMaster-Carr, Grainger, several on-line suppliers, and a few local suppliers) and the people I spoke to said they could not match them because they're two bearings joined as a unit to the shaft. New shaft/bearing sets cost $37 plus shipping. Add that to the cost of the used saw and you're approaching the cost of a new one ~$145. I finally got some pics of the bearings: Chuck
Post by Woodyrock on Nov 1, 2010 18:19:09 GMT -5
Custom bearings are actually quite a rare item.......bearings are very expensive to manufacture, so custom made bearings in a tool like the Rock Rascal are a surprise. Woody
Post by johnjsgems on Nov 1, 2010 18:44:38 GMT -5
$37 for shaft/bearing assy. is still pretty cheap. You are right though. Never buy a used saw unless bearings are good or price is dirt cheap. When I recondition saws for resale I clean, paint, install new belt and blade. If I have to do bearings the saw has to be $20 range. The Rock Rascal is $310 with motor new so lucky to get $125 for used.
Post by Hard Rock Cafe on Nov 2, 2010 9:04:41 GMT -5
The bearings are probably standard, but there are two of them sealed together in a steel collar. The collar can't be opened without destroying it and you need the collar to get the bearings to line up and to fit in the saw.
I have lots of spare motors, so I got the saw without one. If you have your own motor, it brings the cost down to about $150.
Post by johnjsgems on Nov 3, 2010 18:06:53 GMT -5
They really are not "custom made"". I've seen same type of one piece assy's on other types of equipment. Not as easy to find as standard insert or pillow block bearings. Looks like assembly would be really easy to replace.
Post by Hard Rock Cafe on Nov 4, 2010 10:45:05 GMT -5
I'm open to suggestions on the easy replacement in case I ever need to do it in the future.
drjo
Honduran Opal & DIY Nut
Post by drjo on Nov 4, 2010 11:47:48 GMT -5
Can you post pix of old bearings?
Dr Joe
Post by johnjsgems on Nov 5, 2010 17:41:03 GMT -5
If I remember you remove the table and bearing/shaft assy has two screws holding it in.
Post by Hard Rock Cafe on Dec 20, 2010 13:21:03 GMT -5
bump since I added pics
lonetreestudios
RIP Rodney, AKA @lonetreestudios
Member since December 2006
Post by lonetreestudios on Dec 20, 2010 15:26:17 GMT -5
Any possibility of getting a new "collar" of the proper OD, and pressing new bearings with the proper ID into it? Not sure with your arbor if the bearings are pressfit onto the shaft, but even so, I have made it work with heat to the bearing inner race and throw the shaft in the freezer... Just my $.02 worth...
Rodney
drjo
Post by drjo on Dec 21, 2010 8:45:34 GMT -5
Thanks chuck.
Post by Hard Rock Cafe on Dec 21, 2010 9:31:01 GMT -5
Thanks Rodney. Yes, I believe they're press fit onto the shaft and the collar locks them together.
I suppose I could split the collar to get it off the bearings, but I would need some way to join it back to the bearings after replacing them. Since the assembly fits inside the saw, I would have to find a way to do it without increasing the OD.
There comes a point when my time is worth more than the cost of a new assembly. I think this is one of those times.
Post by johnjsgems on Dec 21, 2010 9:58:10 GMT -5
I had the same problem with an old Hope saw (now modified and sold as GyRoc Preformer). I gave up and called Gy-Roc and ordered the shaft and bearing assy. Box said "water pump bearing assy". I don't know if it is automotive or industrial but very similar to your picture.
Post by catmandewe on Dec 21, 2010 18:30:28 GMT -5
Looks to me like you could press the whole assembly off the shaft, then press the bearings out of either end, then press new ones back on from both ends. Don't know if there is a collar on the shaft that the bearings ride against, but at this point I don't think it would hurt to try. You would know right away if it will press off or not. You can find almost any bearing on line if you can find a number, most of them are relatively in expensive too.
Merry Christmas............Tony
Post by johnjsgems on Dec 21, 2010 20:32:04 GMT -5
It is one bearing, not two. No set screws or collars either. The replacement Gy-Roc assembly was shorter and uses a center drilled/tapped hole for a bolt instead of a left hand thread nut. The original looked exactly like the pictured assembly.
Post by cpdad on Dec 22, 2010 21:47:00 GMT -5
you have 2 inverted bearings there...i can tell by the vertical lines on the bearings...they are opposite to each other....so probably a type of thrust bearings for the application....i use the same type set up for other applications...on other stuff i build.
i see numbers on 1 bearing...send them to me...i have bearing details from the 70's and so forth....maybe i can cross reference and tell what ones are needed...maybe.
if we can find those bearings....this should be an easy fix...kev.
QuailRiver
Post by QuailRiver on Dec 26, 2010 18:11:32 GMT -5
The Rock Rascal model "J" uses a standard sized water pump bearing but one that is LH threaded. I found the right size at a local industrial supply company but they only had RH threaded, and non threaded. I think they were around $18.00 each. But since I needed LH treading and don't have access to a metal lathe I went ahead and ordered from Johnson Bros. The new bearing from Johnson Bros also came with new flange washers and a LH threaded arbor nut which I was very happy to get. Outside of the bearings, flange washers and arbor nut there is not much else that can go wrong with one of the model "J"s so I hope I get another 28 years out of this saw before I need to replace anything else. Best Regards, Larry C.
advancedlemon
Member since October 2020
Post by advancedlemon on Oct 26, 2020 20:20:37 GMT -5
Hi,
I'm totally new to this forum so I'm sorry if bumping an old thread is the wrong thing to do, however I have a problem which is very relevant to this previous discussion so it seems like a good place to ask...
I bought an old used Rock Rascal Model J a few weeks back for a steal of a price as it was a bit beaten up. Needed some work to get it running but I got it going the other day and cut a bunch of agates with it. It was great while it lasted but after maybe 50 cuts the blade started to wear seriously out of round which spoilt my fun a bit! (well that and most of the 'agates' were duds!)
Looking for the most likely cause, I'm pretty sure the bearing in my machine is shot as the sealing ring at one end is a bit deformed and leaking oil, and there's a bit of undesirable movement in there. I'm not sure what to do as I'm in the UK. Parts, tools and especially anything lapidary is the pits here these days and to import the official replacement shaft/bearing from the US is probably gonna be very expensive! That said, there's no chance of buying a new lapidary saw here either and I was very lucky to find this one second-hand (used) as it is.
So ... I've had a look for a suitable water pump bearing that'll fit in that housing, thinking that I might be able to get somebody to machine the shoulder for me and cut my own LH thread, which brings me to my secondary problem and the source of my question...
The bearing/shaft assembly in my machine looks just like the one in the picture. It has a standard sized collar, just shy of 39mm long, but the housing on the saw seems to be designed to take a bigger collar as there's maybe 42mm of space in the housing, more or less, depending on how the bearing seals are designed. The previous person had installed what looks like a sanded down 5/8" bore plumbing/poly washer in there to fill the extra space but it wasn't a perfect fit and I think it might have helped to cause problems by putting pressure on the bearing seal rather than on the collar. This is the case because, like the bearing in the photos already in this thread, the sealing rings stick out further than the collar.
I've never seen one of these saws new and I don't know the history of my machine so I just wondered what other Rock Rascal owners have in their machines? Is the original and/or official replacememt bearing larger than a standard water pump size or is that plastic washer or something similar supposed to be in there in my machine? It would be fantastic if somebody with a working Rock Rascal could measure the length of the bearing collar in their machine and chime in, as this could really help me out!
It would be even better if I could also persuade somebody to post a picture of how this is supposed to look when installed in its housing? My bearing housing has what I feel is a rather strange feature: The top part of the housing (the removable bit) has shoulders at one end which provide a recess for the sticking out sealing ring to sit in and give something for the bearing collar to ride against, but the bottom part has none at either end. I feel like there really should be shoulders at both ends of both halves of the housing so that the bearing collar is held securely. This would also reduce the space inside the housing and it might end up properly holding a standard sized water pump shaft assembly if that were the case. So, am I missing something? Is my housing flawed in some way? Another thread here on this forum mentions that the countersunk screw holding the table down also secures the bearing collar in its housing but this is not the case with my machine. It seems very unlikely to solve my problems but could it be that I simply need a longer screw?
Mostly the reason I wish to ask here is because it could save me from the major headache of importing a new bearing from the US only to find it won't fit correctly because my housing is faulty as well! This seems like a very real potential scenario as I find it very hard to believe that the OEM bearing would be a custom size, or that my machine is supposed to contain a plastic washer!
Also, following up on some of the replies already on this thread, obviously I can't speak for the bearing in the original photos here, and mine might not be the same since it doesn't appear to fit properly, however my saw's old bearing bears the text "Moover made in USA" on the seals, and on the end of the shaft are some codes, unfortunately these were partially machined off when the thread was cut. I think they once read "SE-H" and "885502Y", although particularly the numerals are tricky to decipher from just their bottom halves, so either/both of the 8s might be a 6 and the Y might be a 7. The two 5s could be Js or even 3s or 9s, but this is less likely perhaps. "SE-H" could be a manufacturer but it means nothing to me and Google searches for both the possible manufacturer and various possible permutations of the other code was a fruitless exercise.
Any information could be useful so thanks to anybody who is able to reply!
-Tom
advancedlemon
Post by advancedlemon on Oct 26, 2020 20:26:35 GMT -5
I've just realised that came out a bit long oops! Sorry about that. I should've kept my first post a bit shorter!
Still, any advice would be very much appreciated if you can manage to read all that at once!
Cheers,
-Tom
