Post by Roller on Dec 23, 2010 11:51:03 GMT -5
I am a righty so I used up most of my diamond on the right side of my grinding blade .....but the other side is barely touched... is it okay to switch this around ? Also what will this do to the diamonds on the top??? will it refreshen them or makes things worse cutting through a rock that is ...
Post by johnjsgems on Dec 23, 2010 13:00:01 GMT -5
Depends on the blade. All MK/Barranca blades currently available are directional and have diamonds oriented to cut in one direction. These are continuous and segmented types with diamond all through a matrix on blade rim. If you are using tile blades to grind and grind the side of rim down to the level of the core you might have a`problem cutting. If you have a reason to grind with a tile blade maybe you should buy a good blade for cutting and cheapest you can find just for grinding.
Post by Hard Rock Cafe on Dec 23, 2010 13:00:45 GMT -5
I assume you're talking about a continuous rim tile saw blade. Yes, reversing the blade should be fine or you can switch hands or reverse your orientation to the blade.
Post by deb193redux on Dec 23, 2010 14:12:28 GMT -5
the MK225 or MK 303 style blades are directonsl. The diamonds ore angled to cut best. This is less true for the grinding on the side of the balde.
If you just want to get the most of out the blade (which is gonna be done son) you can recverse if for some light cutting and a little grinding.
You need to practive grinding on both sides, and keep in mind it is best to grind on cheaper thicker blades. I would not use an MK 303 as a grinder.
happy cutting
Post by catmandewe on Dec 25, 2010 0:49:12 GMT -5
If it is a directional blade it should have an arrow stamped in it showing which direction to run it. If it doesn't have an arrow you should have no problems turning it around.
Have a Merry Christmas..............Tony
Post by Roller on Dec 30, 2010 0:50:57 GMT -5
thanks guys ///// i already use one blade for cutting which is a directional hotdog blade ... which i wasnt aware of which does have the arrow and another stock qep blade which i use for grindidng ... it grinds!!!!! just takes awhile .... so ehhh ill turn it around and see how it goes its almost done anyways ...
