TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Jan 9, 2011 0:18:09 GMT -5
I was wondering how thick to cut a slab in order to cab it.
I am new and I do not know everything.
Thank you for your help,
Tammy
Post by Sabre52 on Jan 9, 2011 0:29:19 GMT -5
Depends on dome contour you prefer. Most folks like 1/4" thick or even thicker for high domes. I prefer low domes and thinner cabs so I like 3/16". Thicker cabs, if large ones, are quite heavy and require lots more time on the grinding wheels....Mel
cabjunky
Regency Rose Plume
Member since November 2008
Post by cabjunky on Jan 9, 2011 14:50:57 GMT -5
Most of the slabs that I sell are cut at 1/4" thick, but some of the really hard agates i will go down to 3/16" to save on everyones grinding wheels. I like a little higher dome on my cabs.
TByrd
Post by TByrd on Jan 9, 2011 16:38:32 GMT -5
Thank you, my other half will set that size when he sets up the slab saw.
Tammy
Post by krazydiamond on Jan 9, 2011 16:58:37 GMT -5
thicker slabs make bigger cabs, thin ones make good for small cabs, earring size.
KD
Post by frane on Jan 9, 2011 17:26:59 GMT -5
I generally prefer 1/4 inch. If you have a soft stone like calcite or Maraposite, I like them a little thicker because it is too easy to grind away needed mass. Fran
amyk
I'm a slabber, I'm a cabber, I'm a midnight wrapper.
Member since January 2010
Post by amyk on Jan 15, 2011 20:09:03 GMT -5
I make most of my slabs the thickness of a pencil. I don't know how thick that is. I hold a pencil upright against the blade and back up the stone to the pencil and adjust it so it is just as thick as the pencil. Although like Fran said I make it a little thicker if it is soft like onyx or calcite. Otherwise it gets too thin. I like a good dome on my cabs. The slabs I buy are usually too thin to get a good dome. So I have to use it to make smaller cabs. If I want to make a large cab with a good dome I also cut it a bit thicker than a pencil. Of course the pencil I keep by my saw is swollen with oil and won't write anymore. LOL
Post by gr on Jan 15, 2011 20:41:24 GMT -5
Tammy, there's good advise in replys to your post. I cut up alot of slabs when I got my new saw, just to be cutting them with no plan as to what to use them for as a project. And they are all of different sizes (thicknesses). So now if I want to do say, an intarsia project , I have to dig thru all my slabs to find similar thicknesses; which is a pain. Do a little planning and don't waste your material is what I'm trying to say in all of this. Especially if you have to move snow to find a rock to cut. lol
Gary
TByrd
Post by TByrd on Jan 15, 2011 22:01:51 GMT -5
Thank you to everyone for the advice, my other half is cutting them 6 mm thick. If that is not thick enough for a good cab, could you pm me and let me know, I appreciate all of the hints from you guys, it has been great.
