Post by Condor on Apr 17, 2011 20:42:13 GMT -5
Here are a couple of pictures of some rocks I tumbled in the 15lb rotary. There were in 60/90 for seven weeks and Aluminum Oxide for one week. I skipped all the other stages. If the carnelians look familiar, it's because I've posted other photos of others that went through all four stages. Condor
snuffy
Member since May 2009
Post by snuffy on Apr 17, 2011 20:57:18 GMT -5
Excellent shine. Beautiful colors.
snuffy
meta99
Ohio Flint Ridge flint
Member since October 2010
Post by meta99 on Apr 17, 2011 21:07:50 GMT -5
Wow! They look like candy! Eye candy at least....
Now I know what I want to do with my newly acquired carnelians....
Sue
playin4funami
Member since March 2011
Post by playin4funami on Apr 17, 2011 21:19:55 GMT -5
some real lookers in there!
Post by Sabre52 on Apr 18, 2011 12:54:55 GMT -5
Excellent results! Now were those in coarse for seven weeks with no recharges or did you recharge every week? I've never had a lot of luck with shaping when I just let them go without lots of recharging.....Mel
Post by gr on Apr 18, 2011 13:01:05 GMT -5
Condor, what Mel asked and, straight out of A/O or one more step after that? Man those are shinin tall
gr
Post by Condor on Apr 18, 2011 18:15:14 GMT -5
The rocks were in 60/90 without any recharges at all. They went straight to AO. After taking them out of the tumbler I rinsed them as well as I could then cleaned and dried each one with a soft clean cloth (old T-shirt). As far as the shape, the rocks all pretty much had the rounded shape to them. I got them in Tucson and the gentleman who sold me the smaller ones said that he uses those and places them in tumblers with other cracked rough rock. I just placed them in along with the larger carnelians.
Condor
Post by rockrookie on Apr 18, 2011 18:21:39 GMT -5
Nice batch, Condor !!! --paul
Post by susand24224 on Apr 18, 2011 18:27:44 GMT -5
Nice looking rocks, and special thanks for sharing the "experiment."
Susan
Post by gr on Apr 18, 2011 21:22:54 GMT -5
Condor, what I was aksing in my previous post was did you run them thru a borax or some kind of rinse?
gr
Post by tntmom on Apr 18, 2011 21:35:49 GMT -5
Gorgeous shine!!!!
~Krystee
Post by Condor on Apr 19, 2011 15:51:59 GMT -5
Condor, what I was aksing in my previous post was did you run them thru a borax or some kind of rinse? gr No borax or stuff like that this time. All I did was rinse them in the sink thne hand dried each one with a cloth. Condor
Post by stefan on Apr 19, 2011 18:31:18 GMT -5
Interesting method. I've tried that before and it was an utter failure. You had a much better result. Nice shine
Post by stonesthatrock on Apr 19, 2011 18:42:01 GMT -5
the "king ' of tumbling........ wow look at that shine. mary ann
Post by Jack ( Yorkshire) on Apr 20, 2011 1:04:28 GMT -5
Brilliant shine condor
I like carnelian the gloss shine is great as well as the photography any tips ? on taking such a good shine ?
When I take photos on white I get a glare comming back and a lousy photo !
Post by Condor on Apr 20, 2011 18:34:30 GMT -5
Brilliant shine condor I like carnelian the gloss shine is great as well as the photography any tips ? on taking such a good shine ? When I take photos on white I get a glare comming back and a lousy photo ! I took the photos with a Nikon D50 with 18-200mm Tamron lens and had it zoomed in close to 18mm. They were taken outside in the shade with no flash. As for the shine I was just to lazy to change the grit so I left them in the 60/90 until I got the urge to switch to the AO. Condor
Post by Jack ( Yorkshire) on Apr 22, 2011 2:19:03 GMT -5
condor
Many thanks Ill try that I have a Nikon coolpix but I sometimes get a fuzy pic due to shake on Makro,
But one thing that intregues me is how do you get over the thick soup that you get from 60/90 (it seems the grit still kept working ? ) do you just add a bit more water ?
You realy did get a wonderfull shine on them rocks
Jack
Post by Condor on Apr 22, 2011 7:34:36 GMT -5
condor Many thanks Ill try that I have a Nikon coolpix but I sometimes get a fuzy pic due to shake on Makro, But one thing that intregues me is how do you get over the thick soup that you get from 60/90 (it seems the grit still kept working ? ) do you just add a bit more water ? You realy did get a wonderfull shine on them rocks Jack What happens is that after a while the slurry and thickness of the 60/90 just wears down more and more to where it eventually becomes that same as if it were close to perhpaps a 400 grits. So I guess in effect it goes through the different stages on its own. Never did add any more water. Just left them like that until I changed to the AO. Condor
MikeS
Post by MikeS on Apr 22, 2011 17:03:53 GMT -5
killer shine, looks like hard candy!
