Post by mohs on May 17, 2011 22:15:14 GMT -5
a supplier as a bunch of SC belts 8" x 2" they are so old the tape as given out on the belts. These belts sizes are are hard to find
anyone have any idea how I could re-tape the seam? what tape to use ? or other ideas? thanks Ed
Post by gr on May 17, 2011 23:10:29 GMT -5
Ed, if it's a smokin deal,jump on it. We'll figure it out later. I'm thinkin!!
gr
Post by gr on May 17, 2011 23:14:28 GMT -5
You could get in touch with a manufacture and see if they would give up that information. Dr Joe or John at JSGems might have some relevant info
Post by mohs on May 17, 2011 23:19:21 GMT -5
That's a good point Gary
I bought the used expandable wheel from them for five bucks! They said they don't make those belts sizes anymore but he had all these belts that were broken I bought one & tried epoxy'n it kind of failed
but your right ! get the belts for a smoking deal deal with it later always good to have SC belts about
Post by gr on May 17, 2011 23:31:26 GMT -5
$5. for that 8" expando drum!! Score!!! ;D Of course they are 8x3 now, but big bucks (for me anyway) I was just wondering if shipping tape (the kind with the threads in it) would work? An 1" to an 1 1/2" on either side of the joint. It's some pretty stickie stuff
Post by Woodyrock on May 18, 2011 0:34:26 GMT -5
You might try Barge Cement...it is a leather glue, and reuse the original tape. You want the yellow, and red tube. (old formula) the new one is 'compliant' and not near as good. both are still made. to use it put a coating on both surfaces, and wait until it will not stick to your finger. You only get one chance are placement, so be sure you have everything lined up. Woody
Post by mohs on May 18, 2011 0:50:44 GMT -5
I'll check Tandy for that Barge glue that lining up thing though... ?? ![:P](//storage.proboards.com/forum/images/smiley/tongue.png) I better send the job to you ;D Thanks Woody !
drjo
Honduran Opal & DIY Nut
Post by drjo on May 18, 2011 8:22:44 GMT -5
The adhesive will pull off of tape and tape creates a bump too. www.filmtools.com/bace1qshgron.htmlPossibly a flexible epoxy. Use the minimum amount possible as it will squeeze out. Clamping is a must. Good luck and Keep us posted on your progress. Dr Joe .
Post by roy on May 18, 2011 9:01:01 GMT -5
if your wheel is 8x2 cant you get a 8x3 belt and trim it down?
Post by jakesrocks on May 18, 2011 9:11:30 GMT -5
Be interesting to see how things work out. I have several old 6 X 2-1/2" cork polishing belts with the same tape problem. Don
Post by gr on May 18, 2011 10:36:10 GMT -5
Well there ya go Ed, soundslike Barge cement is the way to go. As far as the alignment - make yourself a jig to hold the belt in position
Post by mohs on May 18, 2011 11:32:37 GMT -5
I'm going to re-try with a couple slabs of rock clamped in a vice it may work if it does then I'll be doing a jig ! the coconut rock clomp for me she does the rock'n heart strut ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Post by johnjsgems on May 18, 2011 15:20:34 GMT -5
Can't help you but good luck and keep us informed. I picked up two brand new 8" x 2" drums at a tailgate show once and 3M made diamond belts that size. I think they are a thing of the past. If the diameter is same as the current 8" x 3" drums you could probably use 3" belts and let the extra hang over (if you can't save the old ones). If they are SC belts it isn't worth spending a fortune to salvage them.
Post by mohs on May 18, 2011 15:56:01 GMT -5
These are 3-M belts on Tri-M-Ite cloth so there probably great belts
but you are right John unless I could get them at a killer price even given away AND find an easy efficient way to re-tape/glue them not worth to much hassle and especially the time grind time is at a premium :help:
Post by johnjsgems on May 18, 2011 19:46:32 GMT -5
Ed, before you reglue them measure the length of one. It seems like the drums I bought were labeled for a slightly different size (like the Exact Spans). The standard length should be 25 7/32". I'm pretty sure the drums were in 3M label boxes and DP had 8" x 2" belts in their catalog. New catalog came out with no 3M diamond belts so I don't know if 3M still makes them or not. You will need the exact length for them to work properly.
Post by Roller on May 18, 2011 21:07:23 GMT -5
cant blame us for trying to save a dollar in this messed up economy ...//// ummmm as far as ideas .... hmmm lets see .. something that will be rock solid hard but extremely flexible ... and your answer is === not in my brain ...lo sorry dude .. but these guys who make the belts know .... should we disect them??? i think basically its a sewn together rug with the secret formula...juice...lol ... oh okay sorry now its costing too much ...lol
Post by mohs on May 19, 2011 0:10:27 GMT -5
Ha ha Greg ! i think some gluons are luse in the neurons that's goooddzz jersey stone- mostly
Post by mohs on May 19, 2011 0:13:45 GMT -5
Ed, before you reglue them measure the length of one. It seems like the drums I bought were labeled for a slightly different size (like the Exact Spans). The standard length should be 25 7/32". I'm pretty sure the drums were in 3M label boxes and DP had 8" x 2" belts in their catalog. New catalog came out with no 3M diamond belts so I don't know if 3M still makes them or not. You will need the exact length for them to work properly. Hey John these 3-M belts are indeed 25 7/32". The one I glued did fit the wheel The used expandable is pretty nice metal body and the cushion rubber is in good shape i'll get a 8 x 3 belt to try it but not doing a lot S/C sanding anymore for obvious reasons... Ed
Post by johnjsgems on May 19, 2011 8:23:43 GMT -5
That is the standard size for diamond belts as well.
Post by gr on May 19, 2011 12:30:09 GMT -5
Hey Ed, I've been using SiC to rough preshape with and saving what little diamond I have left for the final shaping. just a thought
