Post by tandl on Jul 21, 2011 9:44:53 GMT -5
I bought this old Star Diamond 10# tumbler at a household auction . The plastic gear on the motor was brittle from age, and lasted about an hour . Where can i get plastic gears for this ?
Post by johnjsgems on Jul 21, 2011 17:39:16 GMT -5
I heard Star Diamond sold their tumbler line to Lortone prior to going under. You might check with Lortone.
Post by tandl on Jul 22, 2011 8:53:57 GMT -5
Thanks, John
smwq4f
Member since January 2014
Post by smwq4f on Jan 7, 2014 0:21:49 GMT -5
I know this thread is a bit old and not sure if you still look at this site, but did you ever find the plastic gear to replace the brittle one that broke? I am having the same issue. Thanks
Post by quartz on Jan 7, 2014 0:28:00 GMT -5
This sort of part is pretty generally "hardware" parts. If you have an industrial supply nearby, see if they handle Boston Gear products, or a related supplier. Boston has a huge assortment of gears available.
MrCoffee
Member since December 2005
Post by MrCoffee on Jan 7, 2014 1:28:54 GMT -5
This is a good thread. I've been looking on EBay for some old Sears Companion 6 pounders made by Star Diamond, and would like to find a source for the rubber barrel liners. No question on the Scott Murray 12 pound metal barrels, Thumlers has them. But the 6 pound is more a specialty item. If anybody does manage to find a set of gears that fit, I'm all ears.
Post by johnjsgems on Jan 7, 2014 9:49:49 GMT -5
For the record, Thumler's (True Square Metal Products) made the 12 (or 15) lb barrels and liners for HP, Contempo, DP and Thumlers model B. The Scott Murray was a little different size. Scott Murray was bought by Lortone so you may find something from them.
smwq4f
Post by smwq4f on Jan 8, 2014 10:54:52 GMT -5
This sort of part is pretty generally "hardware" parts. If you have an industrial supply nearby, see if they handle Boston Gear products, or a related supplier. Boston has a huge assortment of gears available. I will give this a try, although I looked online and I didn't know where to start! Spur gear, helical gear, internal gear I think I might be better off going into someplace.
Post by Hard Rock Cafe on Jan 8, 2014 14:12:33 GMT -5
The Thumler's 12 lb. liner also fits a Star Diamond barrel. The only 6 lb. liners I've found have been used. Can't help with the gear.
Post by johnjsgems on Jan 8, 2014 23:44:38 GMT -5
Somebody made 6 lb. liners that fit inside larger barrels for multiple loads but I don't know who. I saw the barrels years ago at a tailgate sale. The owner of Thumler's told me his B model liner fit everything out there except Scott Murray. I don't think anybody still makes 6 lb. lined barrels. You may have to experiment with repairing the old liners. If you knew what the liners were made of it would be easier but there are compounds for repairing just about everything. Rubber roof repair goup for RV roofs comes to mind.
