gerard
Member since April 2011
Post by gerard on Aug 2, 2011 17:21:32 GMT -5
I am thinking of tumbling larger (2.5" x 3.75" x 1/4) slabs to use as belt buckles. Any of you pros here do that? or have any suggestions as to how to best proceed?
snuffy
Member since May 2009
Post by snuffy on Aug 2, 2011 17:32:08 GMT -5
I tumble lots of slabs that size.These are done in lortone 12 lbers.Important to have a smooth saw cut to begin with. One coarse charge,60/90,run 2 weeks. Then I go 3 days 1000 in lot-o,then 3 days polish in lot-o.Just my method.
snuffy
Post by Sabre52 on Aug 2, 2011 20:48:37 GMT -5
Yep, I've done them in my UV-10 vibe too. Do a short run in the rotary first to round them a bit and use mostly tiny stones in the U-10 with relatively few slabs. I suspect you can comfortably increase the number of slabs and reduce the number of small stones if you want to do more at once but I like to keep a lot of smalls to increase surface area for polishing and act as buffers to prevent edge chipping on the slabs....Mel
gerard
Post by gerard on Aug 3, 2011 10:12:50 GMT -5
"Then I go 3 days 1000 in lot-o,then 3 days polish in lot-o" Scuse my ignorance, but what is lot-o?
Post by johnjsgems on Aug 3, 2011 11:08:55 GMT -5
Lot-O is a brand of vibrating tumbler. UV-10 is another one. I've seen plenty of rotary finished slabs also. Again, you would need plenty of grit carrying media (small stones, ceramic media, etc.).
Post by gr on Aug 3, 2011 13:08:58 GMT -5
I've used aquarium gravel in my rotories thru 600 and then small pre finished quartz rounds the rest of the way and got good results.
Post by deb193redux on Aug 14, 2011 18:01:16 GMT -5
2.5x3.75 is about all large as you will get without going to at 15lb or larger barrel. For est results do all but the course stage in a vibe tumbler. For wind chimes, it is OK to have the edges as rounded as a rotary will make them - but for belt buckles, or any slab put into a finding, you want the edges less rounded.
The advise about small stones and media is good. Keeps the slabs form sticking, and gives plenty of surface area to get good action.
